1 Reply Latest reply on Mar 12, 2012 10:08 PM by kglad
    How can i embed a rss feed to a Flash site?
    fificienta Level 1
      I already made a rss feed. That means i have created a xml file with the rss elements and save it. This is the code:
      <?xml version="1.0" encoding="ISO-8859-1" ?>
      <rss version="2.0">
        <channel>
         <title>RSS Guia Facil</title>
         <link>
      http://es.geocities.com/rss_guia_facil.html
         </link>
         <description>Guia fácil y sencilla sobre el formato RSS</description>
         <item>
          <title>Qué es el RSS</title>
          <link>http://es.geocities.com/rss_guia_facil/que_es_rss.html</link>
          <description>Visita la Guía Fácil del RSS para saber qué es el
         </item>
         <item>
          <title>Para qué sirve el RSSl</title>
          <link>
             http://es.geocities.com/rss_guia_facil/para_que_sirve_rss.html
          </link>
          <description>
          Visita la Guía Fácil del RSS y conoce para qué sirve el
          formato RSS
          </description>
         </item>
         <item>
          <title>Cómo se usa el RSS</title>
          <link>
             http://es.geocities.com/rss_guia_facil/como_se_usa_rss.html
          </link>
          <description>
          Visita la Guía Fácil del RSS para saber cómo usar el
          formato RSS
         </description>
        </item>
      </channel>
      </rss>
      Now i wanna embed the option of rss feed in my website, but it is made in Flash. I have already the code in html for this, it would be like this:
         <a type="application/rss+xml" href="nombre de tu canal RSS.xml">
      <img src="imagen que quieres que sirva de enlace.gif">
         </a>
      But I don't know how to "translate" this code into an actionscript....can anybody help me please!!!???
      Thak u for reading
        • 1. Re: How can i embed a rss feed to a Flash site?
          normally, an rss feed is loaded from another domain.  it looks like you've copied an rss feed and saved it as a local file.
          if you want to use as2 to load a local xml file, use the xml class.  if you want to load the cross-domain rss feed, use the loadvars class to load the return from a server-side script (eg, php) that loads the cross-domain rss feed.
