5 Replies Latest reply on Mar 16, 2012 6:04 AM by kglad
    Filter effect
    santhosh kumar mallepaddy Level 1
      Hi all,
      I tryed to crate a water wave effect using as3.0. I wrote the script like this,
      import flash.filters.*
      import flash.geom.*
      import flash.display.*;
      import flash.events.Event;
      var offset:Array
      var filterList
      //water_mc is the target movie clip
      createWater(water_mc);
      function createWater(target:MovieClip):void {
                target.counter=1;
                target.pt=new Point(0,0);
                target.mpoint=new Point(0,0);
                target.myBitmap=new BitmapData(target.width,target.height,false,0);
                target.myDispl=new DisplacementMapFilter(target.myBitmap,target.mpoint,10,2,0.1,0.15,"clamp");
                target.myList = new Array();
                target.myList.push(target.myDispl);
                target.filters=target.myList;
                target.addEventListener(Event.ENTER_FRAME, onenter)
                function onenter(event){
                               filterList = target.filters
                               offset=new Array()
                               offset[1]=new Object()
                               offset[1].x = target.counter
             offset[1].y = target.counter/8
             target.myBitmap.perlinNoise(45,5,3,50,true,false,5,true,offset)
                               filterList.mapBitmap = target.myBitmap;
                               target.filters = filterList;
                               target.counter++;
      this is I got from some website. I got as2.0 script, I tried to convert that into as3.0,but it is not working. Please help me on converting as2 to as3........
      Thanks in Advance
      Thanks and Regards
      Santhosh Kumar M
        • 1. Re: Filter effect
          copy and paste the working as2 code.
          • 2. Re: Filter effect
            Hi Kglad,
            here is the code......
            import flash.geom.*;
            import flash.filters.*;
            function createWater(target:MovieClip):Void
                      target.counter = 1;
                      target.pt = new Point(0, 0);
                      target.mpoint = new Point(0, 0);
                      target.myBitmap = new BitmapData(target._width, target._height, false, 0);
                      target.myDispl = new DisplacementMapFilter(target.myBitmap, target.mpoint, 10, 2, 10, 15, "clamp");
                      target.filters = target.myList;
                      target.onEnterFrame = function() {
                                filterList = target.filters;
                                offset = new Array();
                                offset[1] = new Object();
                                offset[1].x = target.counter;
                                offset[1].y = target.counter/8;
                                target.myBitmap.perlinNoise(45,5,3,50,true,false,7,true,offset);
                                target.counter++;
            • 3. Re: Filter effect
              use:
                  target.counter=1;
                  target.myDispl=new DisplacementMapFilter(target.myBitmap,target.mpoint,10,2,10,15,"clamp");
                  target.addEventListener(Event.ENTER_FRAME,enterframeF);
              function enterframeF(e:Event):void {
                  var target:MovieClip = MovieClip(e.currentTarget)
                  var filterList:Array=target.filters;
                  var offset:Array = new Array(new Point(target.counter,target.counter/8));
                  target.filters=filterList;
                  target.counter++;
              • 4. Re: Filter effect
                Thanks kglad it's working....... thank you very much.
                • 5. Re: Filter effect
                  you're welcome.
