2 Replies Latest reply on Mar 13, 2012 6:55 AM by NortelT
    Bcc Email button
    NortelT Level 1
      This is the code that I have set up now:
      : "mailto: Katerina.Aburn.ctt@mda.mil,SPPCOHVVITSupportTeam@mda.mil;?bcc=Doe.Loe.ctt@mda.mil;&subject ="+sub+"&body="+ebody,cSubmitAs:"PDF",cCharset:
      "utf-8"});
      In Outlook the following show
      To Line: Katerina Aburn
      CC Line: SPPCOHVVITSupportTeam
      Bcc Line: Nothing shows - what am I doing wrong?
        • 1. Re: Bcc Email button
          dohanlon Level 3
          Tried something similar since yours looks like it is cut off and it worked correctly. I did notice (and its the default behaviour on most email clients i think) is that the bcc line isnt shown be default. In the email client make sure you have display bcc set.
          event.target.submitForm({
              cURL: "mailto: Katerina.Aburn.ctt@mda.mil,SPPCOHVVITSupportTeam@mda.mil;?bcc=Doe.Loe. ctt@mda.mil;&subject=123&body=12345",
              bEmpty: true,
              cSubmitAs: "PDF",
              cCharset: "utf-8"
          Also the CC line wouldnt display since its not set in your example. You have 2 in the To line and one bcc, so you code should probably be
          cURL: "mailto: Katerina.Aburn.ctt@mda.mil;?cc=SPPCOHVVITSupportTeam@mda.mil;&bcc=Doe.Loe. ctt@mda.mil;&subject="+sub+"&body="+body,
          • 2. Re: Bcc Email button
            NortelT Level 1
            Thanks so much, it worked!
