1. Re: Folio Builder Panel: Error #3115
Johannes Eckert Mar 13, 2012 6:05 AM (in response to Johannes Eckert)after doing some reasearch I found out that Error #3115 is normally tied to an SQL database error.
what the hell?
does that mean my local DPS reprository is corrupted? anyone of the techies here to help out?
A few more details: I can log out, this message pops up during log in.
In logged-off mode I can create a new folio, but the panel does not reflect that visually: it shows the "login here" message instead of my local folio.
-Johannes
2. Re: Folio Builder Panel: Error #3115
Jianlan Song Mar 13, 2012 10:10 AM (in response to Johannes Eckert)From another thread it looks like you've got the workaround to delete cache folder. The error means there is problem accessing the offline database in the cache. If you have installed CS6 pre-release bits on that machine and used Folio Builder panel pre-release builds then it is likely the pre-release build was incompatible with release build which is expected. However if you have always been on CS5.5 release builds then it is likely a bug in panel. Unfortunately we have not been able to reproduce the issue internally. If you run into the same issue again, I'd appreciate it if you may ping me jsong@adobe.com. It will help if we can do some simple diagnose in that error state. Thanks!
3. Re: Folio Builder Panel: Error #3115
Johannes Eckert Mar 13, 2012 10:37 AM (in response to Jianlan Song)thanks. the help in the other thread (deleting the cache) helped me out here.
—Johannes
4. Re: Folio Builder Panel: Error #3115
Jianlan Song Mar 13, 2012 1:57 PM (in response to Johannes Eckert)Hi, Johannes:
Do you still have the dmp cache folder on your disk? If so, is it okay if you may forwrad the afc.db file inside the folder to me? It will help a lot for our investigation of the issue. You may email to jsong@adobe.com the file. Thanks!
Jianlan
5. Re: Folio Builder Panel: Error #3115
Jianlan Song Mar 13, 2012 7:52 PM (in response to Johannes Eckert)It turns out to be incompatibility issue with CS6 pre-release build. Details please check out forum thread http://forums.adobe.com/community/dps?view=discussions.
6. Re: Folio Builder Panel: Error #3115
PamShoulder Mar 22, 2012 2:07 AM (in response to Jianlan Song)I have only ever had CS5, no pre-release and have the same error. Where do I find the afc.db file? or the dmb cache
-Pam
7. Re: Folio Builder Panel: Error #3115
PamShoulder Mar 22, 2012 2:22 AM (in response to PamShoulder)Sorry - just remembered - I did have the original pre-release of the DPS - before content viewer was even available.
-Pam
8. Re: Folio Builder Panel: Error #3115
Bob Bringhurst Mar 22, 2012 2:17 PM (in response to PamShoulder)Remove the temporary folders in <username> > Library > Preferences > StageManager.[string] > Local Host, and then try again. If you're on Lion, hold down Option and choose Go > Library to display hidden files. If you're on Windows, drill down to the Local Store folder.
9. Re: Folio Builder Panel: Error #3115
ShruthiSheshagiri Mar 22, 2012 2:28 PM (in response to PamShoulder)PamShoulder, if you have not deleted your afc.db file or if you still have it in your trash can would you mind sending it to ssheshag@adobe.com or jsong@adobe.com? It will help us in investigating the issue if it really is a bug.
Shruthi
10. Re: Folio Builder Panel: Error #3115
PamShoulder Mar 23, 2012 12:05 AM (in response to ShruthiSheshagiri)Hi Shruti
I looked yesterday and don’t have this L
I am no longer getting the message after
Uninstalling everything - Finding my old content bundler -Installing that – to discover that there was nothing on the server anyway
Uninstalled that - And then reinstalled the new Folio Panel 12.1.3 and Folio Producer 1-9-1
Now it simply tells me “You do not have a compatible Digital Publishing Plug-in.
So – the 3115 is sorted but an still stuck. Will be looking for other threads.
11. Re: Folio Builder Panel: Error #3115
PamShoulder Mar 23, 2012 12:16 AM (in response to Bob Bringhurst)Hi Bob
See my reply to Shruti – 3115 has gone but now its not compatible.
-and then (below) which of the Local store folders should I be looking in – and then delete what?
And should I also remove the whole Digital Publishing resources from Plugins folder?
12. Re: Folio Builder Panel: Error #3115
Bob Bringhurst Mar 23, 2012 7:19 AM (in response to PamShoulder)Try solution 2 of this tech note:
http://helpx.adobe.com/digital-publishing-suite/kb/error-do-have-compatible-digital.html
13. Re: Folio Builder Panel: Error #3115
PamShoulder Mar 26, 2012 12:24 AM (in response to Bob Bringhurst)Hi Bob
Did a search for this file and looked manually – it doesn’t exist on my machine.
14. Re: Folio Builder Panel: Error #3115
AadMetz Apr 10, 2012 2:52 AM (in response to Johannes Eckert)@Bob: Can't find my Preferences folder on my Windows(7).
Ga to users; username, but can't find the folder to remover the cache
15. Re: Folio Builder Panel: Error #3115
missamo80 Apr 10, 2012 7:24 AM (in response to AadMetz)The folder is hidden by default if you are using Windows Explorer to find it. The easiest way to get to it is to open the start menu and type in:
%appdata%
Then press enter. From there you can find the com.adobe.dmp.content viewer folder.
Neil
16. Re: Folio Builder Panel: Error #3115
AadMetz Apr 10, 2012 10:51 AM (in response to missamo80)That one did'nt work on my computer.
The thing that works is:
On Win user name/Application Data/applicationID.publisherID/Local Store/
Try follow the steps below:
- 1. Close Folio Builder panel and quit InDesign;
- 2. Find app-storage folder, on Win7 something like c:/Users/[user name]/Application Data/StageManager.BD092818F67280F4B42B04877600987F0111B594.1/Local Store/
- 3. You should find a folder named ‘dmp’ in that folder. Delete ‘dmp’ folder and #sharedObjects in the same folder
- 4. Relaunch InDesign and Folio Builder panel
17. Re: Folio Builder Panel: Error #3115
Bob Bringhurst Apr 10, 2012 11:00 AM (in response to AadMetz)Thanks for providing the steps.
18. Re: Folio Builder Panel: Error #3115
AadMetz Apr 10, 2012 11:19 AM (in response to Bob Bringhurst)And tnx to Jianlan Song, who gave me the answer...:)
19. Re: Folio Builder Panel: Error #3115
gnusart Apr 18, 2012 7:56 PM (in response to Bob Bringhurst)Hi Bob -- I'm beginning to build another app with my college students after a hiatus and want to make sure I do the most stable updates. We're doing a single-edition app with CS5.5. Would you suggest going to Builder 12.1.3 and Producer 1.9.1? We have Builder 11.4.2 on our Macs and I assume the other pieces are of the same vintage ... the Plug-in is 7.xx.18. All advice appreciated! Beth
20. Re: Folio Builder Panel: Error #3115
Bob Bringhurst Apr 19, 2012 6:58 AM (in response to gnusart)Are you creating folios for an existing app in the store? If not, download the newest tools.
21. Re: Folio Builder Panel: Error #3115
gnusart Apr 19, 2012 9:50 AM (in response to Bob Bringhurst)No -- We have to start from scratch with new students and a new magazine app every semester. I see that the Viewer has been approved by Apple, which seemed to be the big issue. I just want to avoid known problems that I may have missed on previous forum posts, if possible.
