Expand my Community achievements bar.
SOLVED
Textfield Title to populate in the subject line of a email button
Avatar
Level 3
I need for the a textfield title to automatically populate in the subject line of the email button
What code goes in sub = ?
var sub
sub =
var ebody
1 Accepted Solution
Avatar
Correct answer by
Level 5
Its probably just as easy to use one single normal button with the following
var sSubject = CTitle.rawValue;
var sBody = <SomeField>;
event.target.submitForm({
    cURL: "mailto: Kat.Art.ctr@mdd.mil;?cc=Don.Bough.ctr@mdd.mil,SPCOHSCITSupportTeam@mdd.mil;&subject=" + sSubject + "&body=" + sBody,
    bEmpty: true,
    cSubmitAs: "PDF",
    cCharset: "utf-8"
use ? for the first parameter and & for each subsequent ones in mailto
View solution in original post
Avatar
Level 3
I created two buttons - one named "Real Email Button"(submit) and one named "Submit Button (regular)"
Real Email button has the addresses listed and the "Submit As" set to PDF:
Submit Button has the following code:
Button2.event__click.submit.target
= "mailto:Kat.Art.ctr@mdd.mil,?cc=Don.Bough.ctr@mdd.mil; SPCOHSCITSupportTeam@mdd.mil?subject= " +
CTitle.rawValue;
Button2.execEvent("click");
I would like the textfield title (CTitle) to automatically populate in the subject line - what is missing in my code?
Avatar
Correct answer by
Level 5
    bEmpty: true,
    cSubmitAs: "PDF",
    cCharset: "utf-8"
Avatar
Level 3
Thank you sooooo much!!!!!
I have been messing with this form for 2 hrs!
