1. Re: Image folders that are found automatically
Steve Werner Mar 13, 2012 12:38 PM (in response to zimbop)I think the linkage would remain if you used the File > Package feature. One of the default options is Update Graphic Links in Package.
2. Re: Image folders that are found automatically
P Spier Mar 13, 2012 12:41 PM (in response to zimbop)Links in InDesign are absolute. If the absolute link cannot be found, ID will search the current folder and subfolders to see if it can locate files with the same names, but this is NOT relative linking.
That's why packaging works. The links, though absolute and broken when you move the package to a new computer, will work because the linked files are contained in a subfolder of the package folder and ID will find them in the subsequent search. If your file transfers include the links in a subfloder they should be found, though you may be asked to update.
3. Re: Image folders that are found automatically
zimbop Mar 13, 2012 12:43 PM (in response to Steve Werner)Hi, I think I need to be more specific about our setup. We are using version control (SVN/Subversion) as a way of maintaining and sharing the project. So I commit files into the system, and my colleague updates his copy so we have the same files. He then opens the document and is immediately prompted with a relink request even though no files have actually been changed. I'm wondering if there are settings or particular folder names that allow InDesign to be able to understand or accept that files which have remained in the same place relative to one another do not prompt this specific behaviour. Sorry if I wasn't more clear in my original post (and hoping that I've cleared this up, I'm trying to be as succinct as possible!).
4. Re: Image folders that are found automatically
P Spier Mar 13, 2012 12:55 PM (in response to zimbop)I don't know a thing about your version control system. Is your colleage really getting a relink request, or an update request? They are different.
Where are these files stored? What does the path look like? What happens afet your colleague is done and you reopen the file?
5. Re: Image folders that are found automatically
Joel Cherney Mar 13, 2012 1:17 PM (in response to zimbop)I'm wondering if there are settings or particular folder names that allow InDesign to be able to understand or accept that files which have remained in the same place relative to one another do not prompt this specific behaviour.
I thought that InDesign would always look in any folder named "Links" that was in the same folder as the InDesign file.
I suspect that Subversion is overkill here, but if that's your preferred project management tool then <shrug>
6. Re: Image folders that are found automatically
P Spier Mar 13, 2012 1:26 PM (in response to Joel Cherney)Joel Cherney wrote:
You might think that, but it isn't actually the case. It only looks inthe links subfolder if the links in the file actually point to that subfolder, or if the real links can't be found. You can demonstrate this by packaging a file (to be sure the links point to the subfolder of packaged links), then copy (not move) the package folder to a new location ON THE SAME Machine so there are two of them. Delete the links subfloder in the second copy and ID will be happy as a clam because it is still using the original links subfolder.
