0 Replies Latest reply on Mar 14, 2012 1:42 AM by Vincent Choy
    InvocationTargetException if php file contains require/include
    Vincent Choy Level 1
      Issue: InvocationTargetException Error when connect to php file. Is it a bug? How to solve it?
      Description: There is a error message when test the php service with flashbuilder function 'Data/Service'-> TestOperation/Configure Return Type. The solution is to remove the 'require' in the php and then flashbuilder works well and return correct return type.
      Error message: InvocationTargetException:There was an error while invoking the operation. Check your operation inputs or server code and try invoking the operation again.
      PHP file for testing:
      <?php
      require ("Random.php");
      class FUNS {
                public function ABC()
                          return "Testing";
