3 Replies Latest reply on Mar 21, 2012 11:54 PM by c.pfaffenbichler
    Determining if a text box was transformed
    StephanPeterson
      I'm trying to find a way to determine if a text box has been transformed. Thus far I've been able to find a way to do so. Any helps would be greatly appreciated.
      I did my best to look through the archive and couldn't find an answer to this. If I missed it, my apologies.
      Stephan
        • 1. Re: Determining if a text box was transformed
          c.pfaffenbichler Level 9
          Could you give this a try?
          Mind you, this only checks for Transformations, not Warped Text!
          // check if text layer has been transformed;
          // based on code by michael l hale;
          // 2012, use it at your own risk;
          #target photoshop
          if (app.documents.length > 0) {
          if (myDoc.activeLayer.kind == LayerKind.TEXT) {
          var ref = new ActionReference();
          ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var layerDesc = executeActionGet(ref);
          var textDesc = layerDesc.getObjectValue(stringIDToTypeID('textKey'));
          try {
                    var theTransform = textDesc.getObjectValue(textDesc.getKey(3));
                    alert ("text layer has been transformed")
          catch (e) {alert ("text layer has not been transformed")};
          else {alert ("not text")};
          • 2. Re: Determining if a text box was transformed
            StephanPeterson Level 1
            It seems to work, thank you.
            Can you help me understand how it's making the determination? I'm an AppleScript guy but am slowly learning JS as needed.
            Stephan
            • 3. Re: Determining if a text box was transformed
              The Script tries to get the Descriptor for Transform from the Text Descriptor.
              If there is none the try-clause fails and the alert is presented.
