1 Reply Latest reply on Mar 16, 2012 10:12 AM by dohanlon
    Dropdown to populate a list in a textfield
    NortelT Level 1
      I need for a to be able to select from a dropdown list and specified item values appear in textfield.
      For example if I select Amy
      If I select Bob
      If  I select Jane
      Amy
      Bob
      Jane (I would like the list to appear as shown)
      I have associated a value to each item in the drop down list so that the selection is easy to compare in order to determine which initial (default) value to set in the text field. In my drop down list's Change event, I have the following:
      var sNewSel = this.boundItem(xfa.event.newText);
      switch (sNewSel)
        case "1": //  Amy
           TextField1.rawValue = "Amy \n";
           break;
      switch (sNewSel)
        case "2": //  Bob
           TextField1.rawValue = "Bob \n";
           break;
      Of course this is not working only name is showing at a time. Please help!
