I need for a to be able to select from a dropdown list and specified item values appear in textfield.
For example if I select Amy
If I select Bob
If I select Jane
Amy
Bob
Jane (I would like the list to appear as shown)
I have associated a value to each item in the drop down list so that the selection is easy to compare in order to determine which initial (default) value to set in the text field. In my drop down list's Change event, I have the following:
var sNewSel = this.boundItem(xfa.event.newText);
switch (sNewSel)
case "1": // Amy
TextField1.rawValue = "Amy \n";
break;
switch (sNewSel)
case "2": // Bob
TextField1.rawValue = "Bob \n";
break;
Of course this is not working only name is showing at a time. Please help!
Solved! Go to Solution.
Views
Total Likes
Not sure what the code is suppose to do, but you basically want to add the name from the dropdown appending onto the current value of the textfield? Why not use the dropdownlist display value directly? For example on the change event :
if ( TextField1.rawValue == null )
TextField1.rawValue = xfa.event.newText;
else
TextField1.rawValue += ( "\n" + xfa.event.newText );
Views
Total Likes
else
Views
Total Likes
That will work!
Thanks for your help
Views
Total Likes
