5 Replies Latest reply on Jun 2, 2015 3:09 PM by MadMac55
    Closing library panels at beginQuit event
    thor2112
      Hello,
      I'm trying to have a javascript run when the user quits InDesign (CS5), and close all the Library Panels.
      The code below (that only closes the Library Panels) works perfect if ran from ExtendScript.  But once I add the EventListener code and then place it in the startup scripts folder, it will loop but never close any panel.  I added the 'n' character so as not to get caught in the infinite loop.
      I've also experimented trying to do this when InDesign is first launched, but it doesn't seem to work either.  I'm wondering if it has something to do with how events work in InDesign, and maybe the Library Panels aren't accessible at these points?
      Any insight would be appreciated.  Thanks!
      app.addEventListener('beforeQuit', save_library, false);
      function save_library(theEvent) {
          var n = 0;
          while(app.libraries.length > 0) {
              var lib = app.libraries[0];
              alert(lib.name);
              //lib.close();
              app.libraries[0].close();
              n++;
              if (n > 7) { break; }
        • 1. Re: Closing library panels at beginQuit event
          Loic.Aigon Adobe Community Professional
          Why not use this line:
               app.libraries.everyItem().close();
          But maybe the issue is that event may not allow application tweaks as it's about to close :S A 2cts thought.
          Loic
          • 2. Re: Closing library panels at beginQuit event
            thor2112 Level 1
            Hi Loic,
            Thank you for your reply.  I gave your code a try, but when quitting the app, the Libraries still wouldn't close - which makes me think it's something with how the event works.
            However, if I reverse things a bit, and run your code when the app first starts up, it works great!  I tried this originally with the code I had, but my code wouldn't work.  Running the code at startup (instead of at quit) will totally work for what I need, so thank you very much for sharing your code and thoughts.  I appreciate it!  :-)
            Jay
            • 3. Re: Closing library panels at beginQuit event
              Matthew.Fry
              Thor2112,
              What does your final version of this script look like?
              Thanks.
              Matt
              • 4. Re: Closing library panels at beginQuit event
                thor2112 Level 1
                Hi Matt,
                Man, this was awhile back, and from what I recall I never found a good solution.
                I've included the code below I came up with at that time, which was AppleScript.  The department who needed this was wanting to be able to have the latest libraries, which were stored on the server, and have them stored to their folder on the desktop if appropriate.
                I was never happy with this, but it was the best I could figure out at that time.
                Jay
                property pServer : "work"
                property pFromTemplatePath : "work:TEMPLATES:image library:"
                property pToTemplatePath : "image library"
                -- Main
                try
                  set errList to ""
                  --tell application "Adobe InDesign CS5"
                  --          set libraryList to libraries's name -- Get Library names that are open
                  --          tell libraries to close
                  --end tell
                  if pServer is not in (list disks) then mountServer()
                  set desktopPath to (path to desktop as string)
                  set toTemplatePath to (desktopPath & pToTemplatePath & ":")
                  if pToTemplatePath is not in listFolder(desktopPath) then
                    tell application "Finder"
                      make new folder at folder desktopPath with properties {name:pToTemplatePath}
                    end tell
                  end if
                  set desktopTemplateList to listFolder(toTemplatePath)
                  set libraryList to {}
                  repeat with i in listFolder(pFromTemplatePath)
                    set i to (i as string)
                    if i is in desktopTemplateList then
                      tell application "System Events"
                        set toMod to file (toTemplatePath & i)'s modification date
                        set fromMod to file (pFromTemplatePath & i)'s modification date
                      end tell
                      if toMod < fromMod then set libraryList's end to i
                    else -- Library file doesn't exist in Desktop folder
                    end if
                  end repeat
                  repeat with i in libraryList
                    try
                      dupeItem((pFromTemplatePath & i), toTemplatePath)
                    on error number n
                      if n is -54 then -- Permissions error
                        set errList to (errList & return & i)
                      else
                        try
                          tell application "Finder" to delete alias (toTemplatePath & i) -- Move to Trash
                          delay 1 -- Give system time to move file to Trash
                          try
                            tell application "Adobe InDesign CS5" to tell library i to close
                          end try
                        on error
                        end try
                      end if
                    end try
                  end repeat
                  --          try
                  --                    repeat with i in libraryList
                  --                              open alias (toTemplatePath & (i as string))
                  --                    end repeat
                  --          end try
                  --end tell
                  if (count errList) > 0 then
                    error ("Can't copy the following Libraries:" & return & errList)
                  else
                    if (count libraryList) > 0 then displayDialog("Templates have been updated!", {"OK"}, 1, 2)
                  end if
                on error Err
                  displayDialog(Err, {"OK"}, 1, 0)
                end try
                -- Bring up sign on window for server
                on mountServer()
                  try
                    with timeout of 9999999 seconds
                      mount volume ("afp://:@TEST/" & pServer)
                    end timeout
                  on error
                    error ("Can't connect to " & pServer)
                  end try
                end mountServer
                -- Duplicate item
                on dupeItem(itemPath, folderPath)
                  with timeout of 1200 seconds -- 20 minutes
                    tell application "Finder" to duplicate alias itemPath to folder folderPath with replacing
                  end timeout
                end dupeItem
                -- Return folder contents
                on listFolder(folderPath)
                  try
                    tell application "System Events" to return (list folder alias folderPath without invisibles)
                  on error
                    error ("Can't get file(s) from folder:  " & folderPath)
                  end try
                end listFolder
                -- Display a dialog
                on displayDialog(txt, btn, def, giv)
                  activate
                  if giv > 0 then
                    display dialog txt buttons btn default button def giving up after giv
                  else
                    end timeout
                  end if
                end displayDialog
                • 5. Re: Closing library panels at beginQuit event
                  MadMac55
                  I have run similar code from js to try and close Libraries.  My simple finding is that palettes that are expanded will close; palettes that are collapsed will not.  It could be a case of trying to find the right language that 1) first expands the palette, then closes the libraries.
                  In this sample, collapsed palettes stay open, expanded will close.
                  function CloseLibraries(myEvent) {
                      var myLibraries = app.libraries; // all open libraries
                      if(myLibraries.length > 0) {
                          var libraryNames = (myLibraries.everyItem(0).name).toString(); // string containing all names
                              for (var i = myLibraries.length - 1; i > -1; i--) { // looping backwards because closing libraries changes the indexes
                                  if (myLibraries[i].associatedPanel != null && myLibraries[i].associatedPanel.visible == true) {
                                      myLibraries[i].associatedPanel.visible = false;
                                  myLibraries[i].close(); // file closed
