8 Replies Latest reply on May 29, 2013 7:28 AM by Rick Gerard
    Using Trapcode Particular on a Motion Path makes the accumulate the first particles like a wheel.
    Guido Giardino F Level 1
      Hi all! Here I bring you a hard one!
      I'm using After Effects CS5.5 and I have a problem using Particular. I have made musical notes that cross a path created by a light called Motion Path 1, like it should be. The first couple of particles cames all together in a wheel.
      In this image you can see the problem. In yellow is the path. In red there are two other particles that make the same thing.
      The only solution I found is to turn off the "orient along path" setting, but it brings a result I don't need. What do you think is happening?
      I bet you can help me, lords!!!
