14 Replies Latest reply on Mar 28, 2012 11:23 PM by Praful_Comp
    How to call web service with basic authentication
    Praful_Comp
      Hi ,
      i want to call web service which has basic authentication
      Also along with web service , i  want to pass 2 parameters to web service function which will return some object.
      can anybody help me plz?
        • 1. Re: How to call web service with basic authentication
          Patel Bharat Level 2
          Hi, try code as below:
          <mx:Script>
          <![CDATA[
                     import mx.rpc.soap.WebService;
                    import mx.rpc.soap.SOAPFault;
                    import mx.rpc.events.ResultEvent;
                    import mx.rpc.events.FaultEvent;
                     private var ws:WebService;
                     private function get_result(evt:ResultEvent):void {
                          // do code here
                     private function get_fault(evt:FaultEvent):void {
                          // error code here
                    private function button_click():void {
                          ws = new WebService();
                          ws.wsdl= "web service path";
                          ws.validateUser.addEventListener("result", get_result);
                          ws.addEventListener("fault", get_fault);
                          ws.loadWSDL();
                          ws.validateUser(userName, password);
          </mx:Script>
          <mx:Button id="button"
                            label="validate user from web service"
                            click="button_click();" />
          • 2. Re: How to call web service with basic authentication
            Praful_Comp Level 1
            Thanks for reply.
            But  this code is not working .
            I also tried validation using
                 ws.setCredentials("username","password");
                 ws.setRemoteCredentials("username" , "password" )
            these are also get failed
            • 3. Re: How to call web service with basic authentication
              For more details, Can you share the code snippets here?
              • 4. Re: How to call web service with basic authentication
                Praful_Comp Level 1
                <fx:Declarations>
                  <s:WebService  id="service"
                   wsdl="web service url" useProxy="false">
                <!-- here login_user is the function in web service which takes 2 parameter as Email and password  and return object as a result which is taken in web_resultHandler(event)-->
                   <s:operation name="login_user" resultFormat="xml" result="web_resultHandler(event)" >
                               <s:request>
                                         <Email>{Email.text}</Email>
                                         <Password>{Password.text}</Password>
                              </s:request>
                   </s:operation>
                </s:WebService>
                </fx:Declaration>
                <fx:Script>
                  <![CDATA[
                   import mx.utils.Base64Encoder;
                   private function authAndSend(service:WebService):void
                          service.setRemoteCredentials('username', 'password');
                         service.send();
                   protected function web_resultHandler(event:ResultEvent):void
                    // TODO Auto-generated method stub
                     var p:Object = event.result;
                </fx:Script>
                <s:Button  label="Sign In"     click="authAndSend(service)"    />
                • 5. Re: How to call web service with basic authentication
                  <s:operation> name is the name of the WebService method. Here we have 'login_user but when it's call ?
                  Refer the link it would me more helpful for that:
                  http://help.adobe.com/en_US/Flex/4.0/AccessingData/WS2db454920e96a9e51e63e3d11c0bf69084-7f db.html
                  • 6. Re: How to call web service with basic authentication
                    Praful_Comp Level 1
                    thanks .
                    But  <s:operation>   can be only used in <webService>
                    I need equivalent component in   <HTTPService>
                    • 7. Re: How to call web service with basic authentication
                      You can use as below:
                      private function send_data():void
                                           userRequest.send();
                      <mx:HTTPService id="userRequest" url="http://localhost/myproj/request_post2.php" useProxy="false" method="POST">
                                   <mx:request xmlns="">
                                            <username>{username.text}</username>
                                            <emailaddress>{emailaddress.text}</emailaddress>
                                   </mx:request>
                      </mx:HTTPService>
                      • 8. Re: How to call web service with basic authentication
                        Praful_Comp Level 1
                        Hi ,
                             authAndSend( ) is not the function defined in web service , I am using this function for web service validation .
                        there is function xyz( ) defined in web service , that i need to call through following code , how to do that ?
                        please help.
                        <fx:Script>
                          <![CDATA[
                           import mx.rpc.soap.Operation;
                           private var getdata:Operation;
                        //function for web service validation
                           private function authAndSend(service:HTTPService):void
                            var encoder:Base64Encoder = new Base64Encoder();
                            encoder.insertNewLines = false;
                            encoder.encode("username:password");
                            service.headers = {Authorization:"Basic " + encoder.toString()};
                            service.send();
                           private function resultHandler(event:ResultEvent):void
                               var webresult:String=event.result.toString();
                           private function resultFailed(event:FaultEvent):void
                            var err:String = event.fault.toString();
                        </fx:Script>
                        <fx:Declarations>
                          <s:HTTPService id="service" url="web service url"
                                resultFormat="xml" result="resultHandler(event)">
                          </s:HTTPService>
                          </fx:Declarations>
                        <s:Button id="button"
                             label="call service"
                        • 9. Re: How to call web service with basic authentication
                          drkstr_1 Level 4
                          To call a specific service method (IE. a SOAP service), you need to use WebService, not HTTPService. HTTPService is for simple GET and POST transactions, where the entire output buffer is read in as the result (usually as a String).
                          Both WebService and HTTPService use HTTP headers to control basic authentication, however, I believe the property is called 'httpHeaders' for a WebService.
                          • 10. Re: How to call web service with basic authentication
                            Praful_Comp Level 1
                            Thanks for reply .
                                 I have also use <webService > component  But authentication is not working .
                            this is my code
                            <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                              xmlns:s="library://ns.adobe.com/flex/spark" title="webservicelattest">
                            <fx:Script>
                              <![CDATA[
                                service.httpHeaders = {Authorization:"Basic " + encoder.toString()};
                                  service.initialize();
                                //service.loadWSDL();
                               // service.send();
                            </fx:Script>
                              <fx:Declarations>
                               <s:WebService
                                id="service"
                                wsdl="web service urll" useProxy="false">
                                <s:operation name="xyz" resultFormat="xml" result="web_resultHandler(event)" >
                                <s:request>
                                <Email>{"email"}</Email>
                                <Password>{"password"}</Password>
                                </s:request>
                                </s:operation>
                               </s:WebService>
                               <!-- Place non-visual elements (e.g., services, value objects) here -->
                              </fx:Declarations>
                               <s:Button  label="call web service"    click="authAndSend(service)"    />
                            </s:View>
                            it is showing me error as
                            [RPC Fault faultString="Could not load WSDL" faultCode="Server.NoServicesInWSDL" faultDetail="No <wsdl:service> elements found in WSDL at ."]
                            at mx.rpc.wsdl::WSDL/getService()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\wsdl\WSDL.as :278]
                            at mx.rpc.wsdl::WSDL/getPort()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\wsdl\WSDL.as:19 9]
                            at mx.rpc.soap::WebService/http://www.adobe.com/2006/flex/mx/internal::wsdlHandler()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\soap\WebService.as:310]
                            at flash.events::EventDispatcher/dispatchEventFunction()
                            at flash.events::EventDispatcher/dispatchEvent()
                            at mx.rpc.wsdl::WSDLLoader/checkLoadsOutstanding()[E:\dev\4.y\frameworks\projects\rpc\src\mx \rpc\wsdl\WSDLLoader.as:203]
                            at mx.rpc.wsdl::WSDLLoader/resultHandler()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\wsd l\WSDLLoader.as:171]
                            at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\http\HTTPService.as:993]
                            at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\AbstractInvoker.as:318]
                            at mx.rpc::Responder/result()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\Responder.as:56]
                            at mx.rpc::AsyncRequest/acknowledge()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\AsyncReq uest.as:84]
                            at DirectHTTPMessageResponder/completeHandler()[E:\dev\4.y\frameworks\projects\rpc\src\mx\me ssaging\channels\DirectHTTPChannel.as:451]
                            at flash.net::URLLoader/onComplete()
                            • 11. Re: How to call web service with basic authentication
                              What you are passing in WSDL ?
                              • 13. Re: How to call web service with basic authentication
                                there should be webservice URL path for wsdl, for example like:
                                wsdl="http://www.abc.com/Flexwebservice.asmx?wsdl"
                                • 14. Re: How to call web service with basic authentication
                                  Praful_Comp Level 1
                                  ya using the same , still not getting validated
                                  please help me to solve the problem .
