2 Replies Latest reply on Mar 16, 2012 9:37 AM by lee704
    Spark syntax for mx:ComboBox editorDataField
    lee704
      I have an mx:ComboBox that I am converying to Spark.  In mx, I used the editorDataField to bind the value selected in a NumericStepper.  Below is the code.
      <mx:DataGridColumn dataField="weight"
                                                 headerText="Estimated Weight (pounds)"
                                                 editable="true"
                                                 width="150"
                                                 editorDataField="value"
                                                 textAlign="right">
                <mx:itemEditor>
                          <mx:Component>
                                    <mx:NumericStepper minimum="0"
        maximum="100000"
        stepSize="1"/>
                          </mx:Component>
                </mx:itemEditor>
      </mx:DataGridColumn>
      How do I accomplish this in Spark?  The following throws the error "Cannot resolve attribute 'editorDataField' for component type spark.components.gridClasses.GridColumn.":
      <s:GridColumn dataField="weight"
                                      editable="true"
                                      width="150"
                                      editorDataField="value">
                <s:itemEditor>
                          <fx:Component>
        maximum="100000"
        stepSize="1"/>
                          </fx:Component>
                </s:itemEditor>
      </s:GridColumn>
      Thanks for your help!
      Lee
        • 1. Re: Spark syntax for mx:ComboBox editorDataField
          Patel Bharat Level 2
          I think this would be helpful to you. Create a custom component, let say Editor.mxml
          <s:GridItemEditor xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                    xmlns:mx="library://ns.adobe.com/flex/mx">
                    <fx:Script>
                              <![CDATA[
                                        // Override the setter to initialize the NumericStepper control
                                        // with the cell data.
                                        override public function set value(newValue:Object):void {
                                                  ns.value = newValue as Number;
                                        // Override the getter to return the current value of
                                        // the NumericStepper control.
                                        // The save() method updates the data provider element for the
                                        // row of the grid with this value.
                                        override public function get value():Object {
                                                  return ns.value;
                                        // Override setFocus() to shift focus to the NumericStepper.
                                        override public function setFocus():void {
                                                  ns.setFocus();
                    </fx:Script>
                    <s:NumericStepper id="ns" width="100%"
                                                              fontWeight="bold"/>
          </s:GridItemEditor>
          And use above class as the column itemEditor.
          • 2. Re: Spark syntax for mx:ComboBox editorDataField
            lee704 Level 1
            That did the trick.  Thank you so much!!
            Lee
