6 Replies Latest reply on Mar 19, 2012 6:42 AM by lee704
    ActionScript Error on MenuBar click event after migrating to Flex 4.5.1
    lee704 Level 1
      Now that I have converted my app to Flex 4.5.1, a MenuBar click event throws the following error:
      TypeError: Error #2007: Parameter child must be non-null.
                at flash.display::DisplayObjectContainer/getChildIndex()
                at mx.core::Container/getChildIndex()[E:\dev\4.5.1\frameworks\projects\mx\src\mx\core\Contai ner.as:2839]
                at mx.containers::ViewStack/set selectedChild()[E:\dev\4.5.1\frameworks\projects\mx\src\mx\containers\ViewStack.as:639]
                at com.views::publicCanvas/mouseClick()[C:\ColdFusion9\wwwroot\ifq2\src\com\views\publicCanv as.mxml:54]
                at com.views::publicCanvas/__menuBar_click()[C:\ColdFusion9\wwwroot\ifq2\src\com\views\publi cCanvas.mxml:86]
      The function throwing the error is:
      private function mouseClick(event:MouseEvent):void
                var tempMenu:MenuBarItem=MenuBarItem(event.target)
                if (XMLList(tempMenu.data).*.length() == 0)
                          publicViewStack.selectedChild=this[(MenuBarItem(event.target).data.@view)];
      The ViewStack is defined as:
      <mx:ViewStack id="publicViewStack"
                                      x="0"
                                      y="22"
                                      width="100%"
                                      height="564"
                                      selectedIndex="0">
                <!-- selectedIndex = 0 -->
                <s:NavigatorContent>
                          <views:publicHomeCanvas id="publicHomeCanvas"/>
                </s:NavigatorContent>
                <!-- selectedIndex = 1 -->
                          <views:viewDealers id="viewDealers"/>
      </mx:ViewStack>
      The menu data is defined in the menuDataPublic.as file as:
      <?xml version="1.0" encoding="UTF-8"?>
      <items>
                <item position="top" label="Home" view="publicHomeCanvas" menuindex="0" />
                <item position="top" label="View Dealers" view="viewDealers" menuindex="1" />
      </items>
      In 3.6, this worked perfectly.  Under 4.5.1 it fails as indicated.  Has anyone run into a similar problem?
      Thank again!
      Lee
