0 Replies Latest reply on Mar 16, 2012 7:20 PM by johnrellis
    Curious severe bug in LrLogger
    johnrellis Most Valuable Participant
      In LR 4, if you call LrLogger (“”) -- with the empty string as the name -- and enable the logger in the plugin's LrInitPlugin, then the logger will enable and capture LR 4's internal logging.  This didn't happen with LR 3.   Using a unique non-empty name avoids this problem.
      With a large catalog, I've observed almost 7,000 log entries per second!  I wonder if at least some of the reports of LR 4 being unusable are caused by this bug? The user of my Any Tag plugin who called my attention to the symptoms was experiencing lots of LR 4 slowth, which disappared as soon as he disabled the plugin.
      Some example log entries:
      12/03/06 06:46:48 LibraryPreloadRootPixels DEBUG requesting preload for image #30: 903294
      12/03/06 06:46:48 LibraryPreloadRootPixels TRACE got results for image:   903294
      12/03/06 06:48:55 DevelopLocalizedSettingsController DEBUG Attempt to get non existent property: gradient.enabled
      12/03/06 06:48:56 DevelopLocalizedSettingsController DEBUG Attempt to get non existent property: gradient.enabled
      12/03/06 06:48:59 LibraryView TRACE For state: loupe, image now entering view: loupe
      Interestingly, there's a log entry hinting at why reverse geocoding failed intermittently when LR 4 was first released; for some reason, perhaps a misconfiguration, Google was limiting the number of queries:
      12/03/06 06:46:47 AgReverseGeocodeService WARN no results in response  OVER_QUERY_LIMIT
