31 Replies Latest reply: Mar 21, 2012 12:59 PM by -==cfSearching==- RSS
    Help creating a stored procedure
    ACS LLC Community Member
      I have a query that is going to run many, many times per day, potentially hundreds of thousands so I want to make sure it's as quick as possible
      The purpose is to take a compiled IP number, look it up and relate it back to the country based on data in the table for current IP/countries
      There are currently 113,536 records in the country table, It's typically taking around 4ms to 5ms, so it's not exactly slow, but as the use of this particular lookup is going to increase significantly I'd like to make sure I have it as fast as possible.
      Here's the current code:
      <CFSET ipnumber = (#listgetat(remote_addr,1,'.')# *256*256*256) +  (#listgetat(remote_addr,2,'.')# *256*256) + (#listgetat(remote_addr,3,'.')#  *256) + #listgetat(remote_addr,4,'.')#>
      <CFQUERY name="GetCountry" DATASOURCE="#datasource#">
          SELECT TOP 1(countryshort) as countryshort
          FROM #ipcountry#
          WHERE ipfrom <= #ipnumber# and ipto >= #ipnumber#
      </CFQUERY>
      The first thought is to try to create a stored proc to see if that generates any performance gain, I've search and read over several documents on setting one up, but I have to admit, I just can't quite grasp it.
      I'm wondering if anybody would be kind enough to stick this query into a stored proc for me and let me know what CF code I need to execute it and read the result.
      Once I see this done I am sure I'll be able to push forward from there on my own in the future
      Mark
        • 1. Re: Help creating a stored procedure
          Dan Bracuk Community Member
          The tag you want is <cfstoredproc>
          • 2. Re: Help creating a stored procedure
            Do you think you could show me how this would look in the stored Proc? I think I could figure out the CF side, it's the SQL stored Proc part that's really getting me
            Btw countryshort is a char(2) and ipfrom and ipto are both big integers
                FROM #ipcountry#
            </CFQUERY>
            Thanks!
            Mark
            • 3. Re: Help creating a stored procedure
              HiTopp Community Member
              CREATE PROCEDURE yourSpName
                   @ipnumber BIGINT
              AS
              BEGIN
                   DECLARE @sql NVARCHAR(MAX)
                   SET @sql = N'
                        FROM ipCountryTable
                        WHERE ipfrom BETWEEN @ipnumber AND @ipnumber -- Not sure why you are using a range here
                   EXEC sp_executesql @sql,
                        N'@ipnumber BIGINT',
                        @ipnumber
              END
              I'm not great with stored procedures either, but I think this should help you.  SQL Server should be able to get you started as well with creating the procedure.  Just make sure you create the procedure within the databse where your IP table is located.
              But for the future, this should really have been asked in a SQL Server forum. http://social.msdn.microsoft.com/Forums/en/category/sqlserver
              • 4. Re: Help creating a stored procedure
                Hi HiTopp
                Thanks for the feedback, I'll definitely connect with the SQL forum :)
                There are two columns in the table and I need to find the number I have as to where it fits in
                1000,2000
                2001,3000
                etc
                so if I have 2500 it is in the 2nd row
                Looks like you missed off the ipto >= bit :)
                    FROM #ipcountry#
                </CFQUERY>
                • 5. Re: Help creating a stored procedure
                  BETWEEN and AND are T-Sql operators that duplicate the exact same thing as <= and >=.
                  http://msdn.microsoft.com/en-us/library/ms187922.aspx
                  • 6. Re: Help creating a stored procedure
                    JR "Bob" Dobbs Community Member
                    Bear in mind that database servers, such as Microsoft SQL Server, will cache the execution plan for parameterized SQL queries which will result in performance gains similar to use of a stored procedure.
                    You might try using CFQUERYPARAM in your queries.  This is also recommended to help prevent SQL injection attacks.
                    You might also create indexes on the ipfrom column on your table.
                    • 7. Re: Help creating a stored procedure
                      The logic does not seem to be correct
                      You have:
                      I have:
                      I am looking for a result where ipFROM <= and another column ipTO >=
                      Bt your statement is just using ipfrom
                      • 8. Re: Help creating a stored procedure
                        Sorry for my ignorance on this but how do you define a parameterized SQL Query?
                        • 9. Re: Help creating a stored procedure
                          You have:
                          I have:
                          My mistake.  I misread your query.  I did not realize you were specifying two different table columns.
                          • 10. Re: Help creating a stored procedure
                            A parameterized query uses bound parameters.  In ColdFusion one uses cfqueryparam to add bound parameters.
                            For example (this assumes that the ipfrom column is a bigint column):
                            <cfquery name="countryLookup">
                                SELECT country
                                FROM ipcountry
                                WHERE ipfrom <= <cfqueryparam value="#ipnumber#" cfsqltype="cf_sql_integer">
                                    AND ipto >= <cfqueryparam value="#ipnumber#" cfsqltype="cf_sql_integer">;
                            </cfquery>
                            References:
                            CFQUERYPARAM
                            http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7f 6f.html
                            Message was edited by: JR \"Bob\" Dobbs Corrected typo in cfqueryparam tags.
                            • 11. Re: Help creating a stored procedure
                              -==cfSearching==- Community Member
                              Agreed. Just wrapping a query in a stored procedures does not mean it is going to run faster. Look at the table's indexes and examine the execution plan to see how it can be improved. And you really should be using cfqueryparam in all of your queries. Not just for performance, but because you are risking sql injection attacks without it.
                              Since the table name is hard coded, there really is not a need for dynamic sql in this query.
                              Message was edited by: -==cfSearching==-
                              • 12. Re: Help creating a stored procedure
                                So you're saying that by using the cfqueryparam that the execution will actually be faster?
                                (Btw Yes it's a bigint, so I presume all cfsqltype are integer if it's tinyint, int, bigint)
                                    SELECT country
                                    FROM ipcountry
                                </cfquery>
                                btw Is a query like this as quick as a stored proc? Is there any performance benefit to the stored proc over this approach?
                                • 13. Re: Help creating a stored procedure
                                  Yes it's a bigint, I presume all cfsqltype are integer if it's tinyint, int, bigint
                                  No, each has a different capacity, which is why they are assigned different cfsqltypes. Refer to the documentation for cfqueryparam linked above.
                                  Bind parameters encourage databases to cache the query execution plan to enhance performance when the same statement is executed multiple times. But many factors affect execution and performance. There is no one-size-fits-all answer. You need to use the available SQL query tools and examine the actual execution plans for your queries yourself.
                                  • 14. Re: Help creating a stored procedure
                                    ahhh ok, JR "Bob" had mentioned, that the command presumed it was a bigint which through me because the type in the example was cf_sqp_integer
                                    So what I actually need is
                                        SELECT country
                                        FROM ipcountry
                                        WHERE ipfrom <= <cfqueryparam value="#ipnumber#" cfsqltype="CF_SQL_BIGINT">
                                            AND ipto >= <cfqueryparam value="#ipnumber#" cfsqltype="CF_SQL_BIGINT">;
                                    </cfquery>
                                    Do you believe that there are cases where the same CFquery which is bound correctly vs a stored proc could give different performance results? Differences that are worth actually bothering about?
                                    • 15. Re: Help creating a stored procedure
                                      The performance benfits of using stored procs come from the database server re-using the same execution plan.  Execution plans can also be re-used for SQL statements with bound parameters, so the performance benefits *should* be about the same.  You would need to use your database's performance monitoring tools to test this assumption.  Not all database systems act the same in how they optomize queries.
                                      I also agree with cfsearching's statement that there is no single right solution to improving query performance.  That being said; I *suspect* that creating an index on the columns used in your WHERE clause will be more beneficial than creating a stored proc.  I encourage you to investigate the performance monitoring tools available for your database product.  Forum users don't have access to your organization's database so any advise we give is limited.
                                      • 16. Re: Help creating a stored procedure
                                        I placed the same code, one with my old SQL the other with a the CFQUERYPARAM and ran repeated tests, now it might not be a great tests because it's just me repeating it rather than a request for different data, the results were 3ms now and again, some 5ms and mainly 4ms response on both, didn't really notice any difference, of course on such a fast query unless it's under a ton of load with many requests for different responses I guess that I won't know for sure.
                                        • 17. Re: Help creating a stored procedure
                                          This probably means that the query is not complicated for the server to parse, but that the work of finding the rows that match your WHERE clause is time consuming.  I will repeat the recommendation that you index the column(s) used in your WHERE clause.
                                          • 18. Re: Help creating a stored procedure
                                            Execution time alone is not a good measurement. Like I mentioned earlier, you must examine the execution plan. Look at how the statement is processed. Does it result in a table scan? Or does it utilize indexes? Does it peform an index scan or seek? Etecetera. That is one of the best tools in your arsenal for guaging performance (which you seem to be avoiding *hint*, *hint*).
                                            For such a simple query, agreed. But do not just guess. Use your query tools to examine the plans and create an effective index.
                                            • 19. Re: Help creating a stored procedure
                                              Sorry, I forgot to mention earlier that the columns ipfrom and ipto are indexed
                                              • 20. Re: Help creating a stored procedure
                                                And what do your execution plans say?
                                                • 21. Re: Help creating a stored procedure
                                                  I am the first to admit that I am no SQL Guru, I know enough to get things functioning with no issues. Right now I just add an index and go with default values, I see you can change the order and maybe other parameters. Is default setting not enough? Appreciate any pointers on this one
                                                  Mark
                                                  • 22. Re: Help creating a stored procedure
                                                    that proves my SQL level I guess.. what are the execution plans?
                                                    • 23. Re: Help creating a stored procedure
                                                      What database product and version are you using?
                                                      • 24. Re: Help creating a stored procedure
                                                        MS SQLServer 2008
                                                        • 25. Re: Help creating a stored procedure
                                                          I'd start with reviewing Microsoft's documentation.
                                                          http://msdn.microsoft.com/en-us/library/ms191227.aspx
                                                          • 26. Re: Help creating a stored procedure
                                                            It's on the to-do list
                                                            • 27. Re: Help creating a stored procedure
                                                              Lol, I have no idea. The "best settings" will vary based on your application, data and queries. You are the only one that has access to
                                                              them. So only you can determine if the settings have the desired effect.
                                                              You have to dig in and start looking at the execution plans. There is a
                                                              lot to digest, and they take a while to fully understand. But that is
                                                              the only way to examine the efficiency of your sql, determine if
                                                              indexes are utilized, compare performance, etcetera.
                                                              http://msdn.microsoft.com/en-us/library/ms189562%28v=SQL.90%29.aspx
                                                              http://msdn.microsoft.com/en-us/library/ms178071.aspx
                                                              http://www.simple-talk.com/sql/performance/execution-plan-basics/
                                                              • 28. Re: Help creating a stored procedure
        I think it might be easier to just throw a bigger server at it if it starts to become a problem!
        I don't think any of my code or SQL is that bad, it's just probably not what a guru would write, but it might suffice. Getting to that next level looks like a long haul!
        • 29. Re: Help creating a stored procedure
        >: It's on the to-do list
        Well move it to the head of the list. Not to be rude, but in the time you have spent on this thread alone, you could have digested a significant amount of the documentation already
        • 31. Re: Help creating a stored procedure
        Sorry, but sometimes the truth hurts ;-) Honestly, I do not always relish pouring over thick tomes of documentation myself. But it has to be done because general advice can only carry me so far. Ultimately, I am the one responsible for coding and maintaining my applications. Since there is no learning by osmosis (though sometimes I wish there were ;-) some things I just have to learn by reading and doing myself. It is just part of the job.
