This content has been marked as final.
Show 4 replies
1. Re: How do I change Form Field type?
Bernd Alheit Mar 17, 2012 11:47 AM (in response to SteveNeedsCalm)Delete the signature field and add the text field.
2. Re: How do I change Form Field type?
SteveNeedsCalm Mar 17, 2012 1:17 PM (in response to Bernd Alheit)Thanks, thats how I did it. I figured there should be an option to change the field type in the properties somewhere instead of haveing to delete and receate stuff. Not exactly user friendly on that one.
3. Re: How do I change Form Field type?
Bill@VT Mar 17, 2012 9:20 PM (in response to SteveNeedsCalm)Used to be back with AA5 or 6 that you could change the type, but that ended several versions ago. So you are stuck with recreation.
4. Re: How do I change Form Field type?
Gilad D (try67) Mar 18, 2012 10:07 AM (in response to SteveNeedsCalm)If this is something that you need to do very often, or to many fields, consider this tool (created by me):
http://try67.blogspot.com.es/2010/10/acrobat-convert-form-fields-type.html
