2. Re: licence limitation for 500 users
shay_df Mar 20, 2012 2:28 AM (in response to Dave Merchant)hello dave,
i just want to make sure i understood:
a) what if i don't use an extended rights form, what i'm doing is extracting the data by a submition button. in this case-is there a limitiation?
b) the same question as a) but using an extended rights form
thanks
shay
3. Re: licence limitation for 500 users
~graffiti Mar 20, 2012 7:34 AM (in response to shay_df)a) The limitation only applies to extended rights documents
b) The limitation only applies to extended rights documents
So you can use a submission button to your hearts content and not reach a limit UNLESS you have that same form with the extended rights. Once you've done that to a form you can only collect 500 instances of date whether it be through receiving the filled in form, hard copies of the form or people using a button to submit the form.
4. Re: licence limitation for 500 users
George_Johnson Mar 20, 2012 8:40 AM (in response to shay_df)Since you've set the form up to only submit the form data and not the filled-in document, you cannot possibly be extracting information "from such Extended Document returned to you filled-in by such Recipients" (to quote from the agreement), regardless of whether the form is extended. A filled-in document is not being returned to you, the form data is. Something other than you extracted it.
