0 Replies Latest reply on Mar 19, 2012 8:40 AM by KevinTUDelft
    ASMock: VerifyError for flash.net.NetGroup (illegal override)
    KevinTUDelft
      I apologise in advance since this question might not be completely appropriate for this forum. Then again it is related to the NetGroup class which I is very related to Cirrus.
      Anyway, I am currently creating automated tests for my project using flexunit4.1 and ASMock (a mocking framework). The problem is that the created mocked NetGroup class has a different signature than the actual NetGroup causing a verifyerror (illegal override). I have tried to pull all projects I have dependencies on and recompile everything with the current compiler in FB 4.6 and the 4.6.0 SDK because I feared the error arose from different SWC files using different SDKs. This is not the case since I have no precompiled SWC libraries linked to any of the projects anymore, they all link to each other and yet the problem persists.
      The exact error message is as follows:
      return types dont match
         virt
      * flash.net::NetGroup/set receiveMode()
         over
      void asmock.generated::NetGroup6B54B8B32216E97DF75A0EBB17879E26E9B81916/set receiveMode()
      VerifyError: Error #1053: Illegal override of NetGroup6B54B8B32216E97DF75A0EBB17879E26E9B81916 in asmock.generated.NetGroup6B54B8B32216E97DF75A0EBB17879E26E9B81916.
      I'll just link the stackoverflow post I made (because it is a bit more verbose) and hope someone can point me in the right direction:
      http://stackoverflow.com/questions/9772656/asmock-verifyerror-for-flash-net-netgroup
