3 Replies Latest reply on Aug 28, 2012 2:56 AM by bruno@CD
    How to shrinkwrap an equation using ExtendScript?
    bruno@CD Level 1
      Hi all,
      Is there any function to shrinkwrap an equation frame? I want to write a script which shrinkwraps all equations in an active document.
      Regards,
      Bruno
        • 1. Re: How to shrinkwrap an equation using ExtendScript?
          frameexpert Level 4
          There is an FCode to shrinkwrap. Otherwise, you can use code to get the parent anchored frame and size it to the size of the equation, while setting the LocY and LocX of the equation to 0.
          Rick
          • 2. Re: How to shrinkwrap an equation using ExtendScript?
            bruno@CD Level 1
            Thanks for the suggestion. Actually, the equation LocY and Loc X should be 1 pt, and the frame width and height 2 pt greater than the equation's.
            function ApplyFormatOnEqn(frame, eqn)
                frame.Width = eqn.Width + 2*65536;
                frame.Height = eqn.Height + 2*65536;
                eqn.LocX = 1*65536;
                eqn.LocY = 1*65536;
            Do you know how to select frames with extenscript, so that I can use the following Fcode?
            function ApplyFormatOnEqnFcode()
                codes = new Array();
                codes[0] = FCodes.KBD_PUTINLINE;
                Fcodes(codes);
            • 3. Re: How to shrinkwrap an equation using ExtendScript?
              bruno@CD Level 1
              Got it:
                  eqn.LocX = 1*65536;
                  eqn.LocY = 1*65536;
                  Fcodes(codes);
              function ApplyEqnFormatBatch()
                  var doc = app.ActiveDoc; // current doc
                  if(!doc.ObjectValid() )
                      Alert ("No active document" ,Constants.FF_ALERT_CANCEL_DEFAULT);
                      return;
                  } // if
                  var frame = doc.FirstGraphicInDoc;
                  // Look for next anchored frame, 40 attempts
                  var i = 0;
                  while (frame.type != Constants.FO_AFrame && i < 40)
                      frame = frame.NextGraphicInDoc;
                      i++;
                  }  // while
              // Check whether eqn is selected
                    if(!frame.ObjectValid()  || i == 40)
                      Alert ("No eqn in this document" ,Constants.FF_ALERT_CANCEL_DEFAULT);
                      return;
                  } // if
                  var eqn = frame.FirstGraphicInFrame;
              // Apply correct format to selected eqn
                  if (eqn.type == Constants.FO_Math) // if equation
                      ApplyFormatOnEqn(frame, eqn);
              // Loop if there are more eqns
                  while(frame.NextGraphicInDoc.ObjectValid())
                      if (frame.type == Constants.FO_AFrame)
                          if (eqn.type == Constants.FO_Math) // if eqn
                  } // while
              } // function
