Greetings.
I have created a service and vo on my server. I have verified they work and return data.
I have copied the vo (value ordered) class to my flashbuilder. it is identical to my file
on the server. I have created the TrailerVO.as file defining my class.
When I retrieve data, I can display all the data, except the field named maxwidth.
The field maxwidth was added after I had already got things working. I can
see in the Network monitor that the maxwidth data is being returned from teh server,
but it just won't display. Maxwidth is integer.
I examined the_Super_TrailerVO.as file and it does not contain the maxwidth.
Is there a way to get flashbuilder to regenerate this file ?
Any ideas why I am getting this error?
thanks.
The answer is:
once you change the VO, you need to go to the Data/Services tab. Right click on the method and choose "configure return type"
which will pull in the new fields.
