5 Replies Latest reply on Mar 25, 2012 12:04 AM by Green4ever
    Placing an Marginal elements using object styles
    Learner X Level 1
      While i am using this following script i found this error.
      1. Paragraph style = TA
      2. Object style = TA
      3. Library Name = ANNO
      //Script start from here
      main();
      function main(){
          if (app.documents.length!=0){
              if(app.libraries.length!=0){
              myStyleDialog();
              else {
                  alert ("Please open the Library.");
          else {
              alert ("Please open a document and try again.");
              exit(0);
      function myStyleDialog(){
      var myLabelWidth = 120;
      var myParaStyleNames = myGetParagraphStyleNames();
      var myObjStyleNames = myGetObjectStyleNames();
      var myDialog = app.dialogs.add({name:"Choose Styles to Place Anchor"});
      with(myDialog.dialogColumns.add()){
          with(borderPanels.add()){
              with(dialogColumns.add()){
                  with(dialogRows.add()){
                          staticTexts.add({staticLabel:"Paragraph Styles:", minWidth:myLabelWidth});
                          myParaStyleDropdown = dropdowns.add({stringList:myParaStyleNames, selectedIndex:0});
                                  staticTexts.add({staticLabel:"Object Styles:", minWidth:myLabelWidth});
                                  myObjectStyleDropdown = dropdowns.add({stringList:myObjStyleNames, selectedIndex:0});
          myReturn = myDialog.show();
          if(myReturn == true){
               myParagraphStyle = myParaStyleNames[myParaStyleDropdown.selectedIndex];
               myObjectStyle = myObjStyleNames[myObjectStyleDropdown.selectedIndex];
               myDialog.destroy();
            else {
            myDialog.destroy();
      function myGetParagraphStyleNames(){
          var myStyleNames = app.documents.item(0).paragraphStyles.everyItem().name;
          return myStyleNames;
      function myGetObjectStyleNames(){
          var myObjStyleNames = app.documents.item(0).objectStyles.everyItem().name;
          return myObjStyleNames;
      var myDoc = app.documents[0];
      var myLib = app.libraries[0];
      app.findTextPreferences = NothingEnum.nothing;
      app.changeTextPreferences = NothingEnum.nothing;
      app.findTextPreferences = null;
      app.findTextPreferences.appliedParagraphStyle=myParagraphStyle;
      myFind = myDoc.findText(true);
      var myCount=0;
      for (i=0; i<myFind.length; i++)
          myText = myLib.assets.item ("ANNO").placeAsset (myFind[i].insertionPoints[-1])[0];
          //<<replace>> myText.insertionPoints[0]=myFind[i].contents;
          //<<>>myText.appliedObjectStyle = myObjectStyle;
          //<<>>myText.contents=myFind[i].contents;
          myFind[i].move (LocationOptions.after, myText.insertionPoints[0]);
          myText.appliedObjectStyle = myDoc.objectStyles.item (myObjectStyle);
          myText.fit(FitOptions.frameToContent);
          myCount++;
      alert(myCount+" ANNOs are Placed Successfully...");
      For your more information i attach the file.
      Please give any solution for above mentioned issues. Where i want to change in this script?
      Thanks in advance...
