2 Replies Latest reply on Mar 20, 2012 3:46 PM by apmaui808
    Stopping the File Open At the End of Loop
    apmaui808
      How can I make the script skip the "docRef = open(fileList[i])" at the end of the iteration once all the files are opened? Is there a way to get rid of
      this by perhaps getting the total number of files on a folder and assigned it as a variable 'max", such that if the variable "i" is eventually equal to
      "max," the the script will not execute the last action on the iteration?
      As of now, this loop (taken from Paul Riggott's response to my question before regarding folder processing) is generating the following error:
      Error 8000: Cannot open the file because the open options are incorrect
      Line: 20
      -> docRef=open(fileList[i]);
      Here is the script I am working on:
      var startDisplayDialogs = app.displayDialogs
      app.displayDialogs = DialogModes.NO
      // ask the user for the input and output folders
      var inputFolder = Folder.selectDialog("Select a folder to process")
      var outputFolder = Folder.selectDialog("Select a folder for the output files")
      if (inputFolder != null && outputFolder != null) {
      // get all the files found in this folder
      var fileList = inputFolder.getFiles()
      // open each one in turn
      for (var i = 0; i < fileList.length; i++) {
      // The fileList includes both folders and files so open only files
      if (fileList[i] instanceof File && fileList[i].hidden == false) {
      // get a reference to the new document
      var docRef = open(fileList[i]);
