0 Replies Latest reply on Mar 20, 2012 6:51 PM by ChemProtocol
    ROUNDING - Automatically rounding to whole Number - HELP
    ChemProtocol
      Hi all,
      Have a major problem using LC version 8. Designing on-line chemotherapy templates for the hospital.
      Issue:
      1. calculated fields are automatically rounding to the whole number
      2. subsequent global values are rounded even if I use: $=round($,2) for the first calculated field
      The only area in the form where I deliberately made the decimal round is by using javascript:
      function roundNumber(num, dec) {
              var result = Math.round(num*Math.pow(10,dec))/Math.pow(10,dec);
        return result;
      BSA.rawValue=roundNumber(Math.pow(Table34.Row1.wt.rawValue,0.425) * Math.pow(Table33.Row1.ht.rawValue,0.725) * 0.007184,2);
      I'm really stuck as a lot of the drug calculations are reliant on the accuracy of weight, body surface area etc
      Here is the working example: http://www.lotusinteractive.com.au/chemo_adobehelp/CLADRIBINE.pdf
      Note: BSA works fine (height and weight data need to be added to get the BSA value). The percentage dose is filled in to used to get the CALCULATED DOSE value (0.14mg x weight)
      eg. if weight is 55kg X 100% (0.14mg) the result should be = 7.7mg
      Result calculated is = 8mg
      HAS ANYONE GOT ANY IDEAS???
