2 Replies Latest reply on Mar 21, 2012 7:57 PM by phneville
    Date format
    phneville Level 1
      I have a property of type Date formatted like so 2007-01-15T00:00:00.000+08:00.
      Would there be problems if I change that value to 2007-01-15T00:00:00.000+0800 (without the colon on the timezone offset part)?
        • 1. Re: Date format
          hypnotec Adobe Employee
          you cannot change the "format" of the date stored in a date property. you can of course format the output after reading the date from the property:
          via sling API / resource resolver:
          ValueMap properties = resourceResolver.getResource("/my/node").adaptTo(ValueMap.class);
          Calendar cal = properties.get("myDate", Calendar.class);
          or via JCR api:
          Calendar cal = session.getNode("/my/node").getProperty("myDate").getDate();
          and then format:
          String formattedDate = new SimpleDateFormat("yyyy-MM-dd").format(cal.getTime());
          • 2. Re: Date format
            phneville Level 1
            Thank you.
