1. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
SAFEHARBOR11 Mar 21, 2012 6:38 AM (in response to J Maggs)Have you ran a head cleaner tape? It does sound odd that the dropouts are timed out, but let's eliminate dirty heads from the equation
Jeff Pulera
2. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
Ann Bens Mar 21, 2012 7:01 AM (in response to J Maggs)I am not a fan of batch capture. I capture the whole tape with scene detections. Scenes i do not use i delete from the hard drive.
Make sure you capture to an internal 7200 drive.
And do run a cleaning tape once in a while.
Dont use the tapes again.
3. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
John T Smith Mar 21, 2012 8:20 AM (in response to J Maggs)Try this for HDV capture http://strony.aster.pl/paviko/hdvsplit.htm
4. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 22, 2012 2:36 AM (in response to SAFEHARBOR11)Thanks for the replies.
I have tried a head cleaner with no luck. To make sure I also loaded them with a second camera but the same dropouts occurred, and about the same intervals (approx 58 seconds).
5. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 22, 2012 2:38 AM (in response to Ann Bens)Thanks for the suggestion Ann. But I have also tried capturing to both my internal drives, both a 7200 drive, and my 10,000 rpm Veloci Raptor Drive. The error remained. I also used scene detection when I have captured the footage.
6. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 22, 2012 2:41 AM (in response to John T Smith)Thanks John. Will give that program a run and see how it goes. Appreciate the help everyone.
7. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
JSS1138 Mar 22, 2012 10:14 AM (in response to J Maggs)same dropouts occurred, and about the same intervals
That suggests some background process on your computer is interfering with the capture process.
8. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
Harm Millaard Mar 22, 2012 10:35 AM (in response to J Maggs)(used Sony HDV mini DV tapes)
That is a cardinal sin. Never use a tape twice.
9. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 22, 2012 7:47 PM (in response to Harm Millaard)Thanks harm, but the tapes were only recorded on once, but I captured from them twice to test the error. These were all brand new tapes used.
10. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 22, 2012 7:53 PM (in response to JSS1138)Thanks Jim. I am inclined to agree with all the testing done. I tried something last night and just played the tapes through the capture window in PPro, and I could actually watch the loss of signal/ break up while it was playing through the window. The viewfinder on the camera at the same time showed no problem, but in the capture window it would pause and jump. This happened at around the same interval as the captured errors.
If its not a PPro problem I will have to start thinking its hardware. It will break my heart it I end up figuring out my Quadro FX5800 graphics card needs replacing. My wallet would cry too.
11. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
JSS1138 Mar 22, 2012 8:49 PM (in response to J Maggs)I'd be looking at the running processes before I started looking at hardware error.
12. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
Helmuth Fischer Mar 22, 2012 11:42 PM (in response to J Maggs)Hi there,
I record with Canon XL H1 and have used tapes many times over and never had any serious drop out. I play them back via SONY HDV recorder into my PC.
14. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 25, 2012 9:22 AM (in response to JSS1138)Thanks Jim,
I have tried this, but am not quite sure what I'm looking for. There seems to be numerous running processes going, and have tried playing the video feed whilst watching the error occur. Is there something that would stand out or to look for? Appreciate the help. I now know at least this isn't an Adobe problem, and won't waste the forums time with any more questions. But it appears when playing through the capture window the glitch appears about every mintue without fail. I guess its just trying to work out what's popping up at the time to cause it. -
15. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 25, 2012 8:49 AM (in response to chesterr_mizik)Thanks for the link chesterr, but it appears to be broken and cant see the article.
16. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 26, 2012 12:04 AM (in response to JSS1138)Jim,
After some looking around, there was something intergering with the capture in the background process. I didn't know how it could cause this problem, but I added a wireless adaptor in my spare PCI slot for internet when I moved rooms. On the off chance I have disabled it and tried the capture again. The whole tape was captured without an issue. Obviously some sort of compatibility issue, but at least I now know Premeire and the rest are working as they should. Thanks all for all the help. Much appreciated.
17. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
John T Smith Mar 26, 2012 8:08 AM (in response to J Maggs)Glad you found the problem... it appears that your wireless card was asking 'anybody there want to talk to me?' at regular intervals
19. Re: Help! Regular Drop outs whilst importing HDV Video on Premiere Pro CS5.
J Maggs Mar 27, 2012 5:10 AM (in response to John T Smith)Lol, that it was John. That is until I smacked its *** and disabled it.
