0 Replies Latest reply on Mar 21, 2012 9:14 AM by petrij_4567
    How can I find my custom panel in CS5 using java script
    petrij_4567
      -I made an empty panel using Adobe Configurator 2 and then exported it to /Panels folder.
      -My custom panel is now in photoshop and works.
      -I added a simple code to onPanelInit():
      function onPanelInit()
          var myWindow = new Window ("dialog");
          var myMessage = myWindow.add ("statictext");
          myMessage.text = "Hello, world!";
          myWindow.show ( );
      so far so good.
      Now instead of creating a new window like I did above, I want to use the new custom panel and add a text to it.
      The problem is, how do I do that in java? Where can I find the panel that I should assign the text to?
      I know that you can add the text in Configurator, or you can edit the .xml file and add the button there, but my
      plan is to create a panel where i can add and remove buttons dynamically and that's why I have to do that in java.
      Any help would be appreciated!
      Cheers,
      Petri J
