0 Replies Latest reply on Apr 14, 2008 5:53 AM by aaronmartinez
    CFPDF and DDX instructions
    aaronmartinez
      I'm trying to use the processddx action of the CFPDF tag to set the intial view of a PDF generated by CFDOCUMENT, but I'm only having any luck when the source and output documents are actual physical files on the server. If I try to use the variable generated by CFDOCUMENT in the structure for the 'inputfiles' attribute I get a "B cannot be cast to java.lang.String" error thrown, and it doesn't look like I can even specify a memory variable for the 'outputfiles' attribute of the CFPDF tag.
      Can anyone help? Has anyone been able to apply a DDX transformation to a memory-resident PDF variable and then written it back to memory, and not to disk?
