1 Reply Latest reply on Aug 28, 2006 10:18 PM by Craig Grummitt
    Newbie question about Dynamic Text + ActionScript
      I've got a two keyframe file. Frame 1 has a dynamic text block instance called "my_txt".
      Frame 2 has the following actionscript (and does not contain the dynamic text block):
      When testing this file the screen is blank and the playhead seems stuck on frame 1. I would expect the movie to progress to frame 2, change the dynamic text, go back to frame 1 and blink "hello" in an endless loop.
        • 1. Re: Newbie question about Dynamic Text + ActionScript
          Craig Grummitt Level 3
          two things - you can only set the contents of a textfield if that textfield exists currently on the stage. so if on frame 2 you're trying to set the contents of my_txt and my_txt does not exist on the stage, then nothing will happen.
          second - although it may look as though it is stuck on frame 1, it is actually going to frame 2, but because the actionscript on frame 2 tells flash to go to frame 1, it does this instantaneously rather than playing frame 2 at the frame rate of the fla.
