1 Reply Latest reply on May 30, 2012 9:11 AM by sinthetic4U
    Upgrade ES2.5 to ES3
    sinthetic4U
      hello everybody
      we've installed es3 a couple of weeks ago and now i've to adapt the services for that which is a little bit of a problem.
      maybe someone have a clou or so.
      first the setup:
      we are running es3 on redhat linux & jboss server
      there is one process deployed which just distinguishes if it should build pdf or ps files.
      we are connecting to this process like the below example
      ServiceClientFactory srvClientfactory = ServiceClientFactory.createInstance(props);
                      parameter = getInputParameters(request,tmpXdpName, formDoc,docData, outputPath, outputFilename);
                      InvocationRequest lcRequest = srvClientfactory.createInvocationRequest(PROCESS_NAME, OPERATION_NAME, parameter, true);
                      lcResponse = srvClientfactory.getServiceClient().invoke(lcRequest);
      when running this code it works for 2.5 but not for 3.0 - the error is always
      java.lang.IllegalStateException
      now i searched for the new jbossall_client.jar and found it - strangely this one has now only about 4 KB - mine has 4.5 MB ...
      last time i've upgraded from 8.0 to 9.x it worked with a little bit of a change - now i'm a little lost ...
      is there anybody out there who has a hint or so?
      don't know which api now is currently used or has to be used!
      thank you
      andy
