2 Replies Latest reply on Mar 22, 2012 10:17 AM by celuloyd
    InDesign CS4 crashes when converting 1-column text box with drop shadow to 2-col (or more)
    celuloyd Level 1
      I'm using InDesign CS4 in Windows XP Pro 64-bit, 6GB RAM. If I create a 1-column text box, fill it with a color, add a drop shadow, then add text, everything is fine. If I try to change it to 2-columns (or more), InDesign freezes/crashes. I thought at first it might be because the box was rotated, but it happens even if the box isn't rotated. If I take the drop shadow off and try to change it, it works.
      Does anyone know why this is happening or if there is a known bug or fix?
      Lloyd Lathrop
