9 Replies Latest reply on Mar 23, 2012 8:28 AM by kglad
    _global variable
    armandix
      Hello friends,
      I have a swf page where the external swf will load, there is any way to declare variables who work in all swf.
      What I am trying to do is:
      like a switch , with several options in which all these are listed in the main swf
        • 1. Re: _global variable
          using _global when setting your variable should work.  of course, you can't retrieve that value until after it's set.
          • 2. Re: _global variable
            armandix Level 1
            I have done this:
            if(_global.menux == 1){
                _root.menu_side.side.lateral.item1.gotoAndPlay("s1");
               _root.menu_side.side.lateral.item2.gotoAndStop(1);
            } else if (_global.menux == 2){
                _root.menu_side.side.lateral.item2.gotoAndPlay("s1");
                _root.menu_side.side.lateral.item1.gotoAndStop(1);
            }else{
                trace(_global.menux);
            but when I click in each button , the trace should be trace the button value
            • 3. Re: _global variable
              i see no button handlers and i see no trace functions and i see nowhere that menux is defined.
              • 4. Re: _global variable
                armandix Level 1
                Kglad in my first frame in time line I have
                _global.menux = null;
                In the third frame I have the following code:
                }else{
                the buttons have the following code:
                on(release){
                _global.menux = 1;
                The value should be printed , but shows nothing...
                • 5. Re: _global variable
                  does your 3rd frame execute after a button is released?  if not, that code's not going to work.
                  • 6. Re: _global variable
                    armandix Level 1
                    action and the button are on the same frame, but yes  execute after release button,and does show nothing
                    • 7. Re: _global variable
                      if that were true you would see 1 then 2 in the output panel, not 2 then 1:
                      trace(1);
                      }else{
                      on(release){
                      trace(2);
                      _global.menux = 1;
                      • 8. Re: _global variable
                        armandix Level 1
                        Tanks, Kglad
                        • 9. Re: _global variable
                          you're welcome.
