3 Replies Latest reply on Mar 22, 2012 12:59 PM by Zoffix222
    Lost In The Docs / Data Merge
    Zoffix222 Level 1
      Hey,
      I'm trying to cook up a script that would add one of the items in my "data merge" into a text frame.
      I have the code below, and I'm trying to understand the scripting help file, but so far I was only able to output some kind of resolve(....) text.
      The "310-7251" is a name of one item in my data merge list. I want the text frame to contain it's.. um.. reference(?), the "<< 410-7251 >>" text that I would get if I did this manually, that would turn into the field's value when I would create a merged document.
      What am I doing wrong?
      var doc
      = app.documents.add();
      var text_frame = doc.pages[0].textFrames.add();
      text_frame.geometricBounds = [
      '0pt', '115pt', '240pt', '240pt',
      doc.dataMergeProperties.selectDataSource('E:/Temp/Merge-Test.csv');
      text_frame.parentStory.insertionPoints[-1].contents += doc.dataMergeTextPlaceholders.item('310-7251').toSpecifier();
        • 1. Re: Lost In The Docs / Data Merge
          Zoffix222 Level 1
          This code inserts a type of thing I want, but it works only with the .firstItem() on the last line. I want to call up the field by name, but when I use doc.dataMergeProperties.dataMergeFields.item('310-7251') there, it errors out saying "expected DataMergeField but received nothing". I even outputted the fieldName out of the .firstItem() to ensure I got the name right, but it still doesn't resolve to anything :/
          var doc
          doc.dataMergeTextPlaceholders.add(
          text_frame.parentStory,
          text_frame.parentStory.insertionPoints[-1],
          doc.dataMergeProperties.dataMergeFields.firstItem()
          • 2. Re: Lost In The Docs / Data Merge
            Zoffix222 Level 1
            Weird, if I do alert(doc.dataMergeProperties.dataMergeFields.item('310-7251')) I receive a message with "[object DataMergeField]", same as with firstItem(), but even if I try to view it's .fieldName property, I get an error saying invalid object.
            • 3. Re: Lost In The Docs / Data Merge
              Zoffix222 Level 1
              Well, I gave up and wrote a function that would traverse all the items and find the one I want.
              With my extremely limited knowledge of the language, it seems there's a bug with the item() method; it doesn't accept field name string properly.
              Here's my code that finally worked, but I'd love to know what I was doing wrong.. Thanks.
              var doc          = app.documents.add();
                  get_field('310-7251', doc)
              function get_field(field_name, doc) {
                  var fields = doc.dataMergeProperties.dataMergeFields;
                  for ( var i = 0, l = fields.length; i < l; i++ ) {
                      if (fields[i].fieldName == field_name) {
                          return fields[i];
                  alert('Error: did not find any fields with name ' + field_name);
