1. Re: I encountered a bit of difficulty opening a .Tif file which was saved in CS5?
-Agfaclack- Mar 22, 2012 4:23 PM (in response to patlannon)my glas orb is defect,.. what problem exactly?
2. Re: I encountered a bit of difficulty opening a .Tif file which was saved in CS5?
patlannon Mar 22, 2012 4:36 PM (in response to -Agfaclack-)The problem was the tiff file opened and immediatly closed down in CS6, it didn't freeze the app but the image could not be seen until the third try.
I am wondering if this kind of issue has been seen by others.
3. Re: I encountered a bit of difficulty opening a .Tif file which was saved in CS5?
-Agfaclack- Mar 22, 2012 4:42 PM (in response to patlannon)i have opended at least 70-80 images today.. all of them tif most with LZW compression and had no problems.
4. Re: I encountered a bit of difficulty opening a .Tif file which was saved in CS5?
Chris Cox Mar 22, 2012 6:29 PM (in response to patlannon)If Photoshop was still running, but you couldn't see the image in the document window -- then that's probably a bug in your display driver.
Try updating your video card drivers from the GPU maker's web site.
5. Re: I encountered a bit of difficulty opening a .Tif file which was saved in CS5?
Jeffrey Tranberry Mar 22, 2012 9:44 PM (in response to patlannon)We'll need a lot more information about your system and steps to repro: FAQ: I found a bug. How do I write a useful bug report?
6. Re: I encountered a bit of difficulty opening a .Tif file which was saved in CS5?
patlannon Mar 23, 2012 6:23 PM (in response to Jeffrey Tranberry)I am using an hp laptop dv7t, it runs win 7 64bit and has an intel graphics co-processor.
The machine has a total of 6 gig of ram.
The processor is an i5 cpu M460 @ 2.53GHz.
The fact that the system had difficulty opening the .tif it has opened without further problems after re-boot several times. I've opened approximately 50more .tif files without incident.
