0 Replies Latest reply on Mar 22, 2012 7:58 PM by simon.oconnor
    I've started updating Flare for use with Flex/Spark
    simon.oconnor Level 1
      Flare is a pretty cool actionscript library which allows you to make some pretty great interactive visualisations (or visualizations if you're American) of data. A couple of problems with it though:
      • It has pretty awful documentation. There's a tutorial that gets too in depth, too quickly and doesn't outline how to get up and running quickly at all, or what form of data is expected. &
      • It doesn't play all that well with the Spark architecture, making you 'hand draw' things on the nodes of a chart rather than just applying skins.
      I'm trying to rectify this by:
      The quickstart guide should get anyone up and running with Flare using the downloadable version there is from them.
      The second post has a partially recoded version of Flare to be friendly with Flex. I've worked on it more since then, and will continue to post updates as I get more and more working and cleaned up.
      I hope this will be helpful, as Flare has some pretty cool things going for it (and some baffling choices also!).
