16 Replies Latest reply on Mar 25, 2012 9:51 PM by manojb05
    mouse over effect
    manojb05 Level 1
      Dear all
      I am watched a website nicely done a mouse over link  look "Postgraduate studies, Undergraduate Studies etc.." how can this do please help me
      web link
        • 1. Re: mouse over effect
          The link you show appears to just be using a mask that drops down over the content that appears when you rollover the button (movieclip)
          If you search Google using terms like "AS3 animated button tutorial" you should find some useful tutorials to get you started.
          • 2. Re: mouse over effect
            manojb05 Level 1
            ned murphy AS2 is not workable?
            • 3. Re: mouse over effect
              manojb05 Level 1
              murphy i dont get similar tutorial please help this.
              Anybody know how ca do this type buttons
              • 4. Re: mouse over effect
                YOu can do the same using AS2, only the code would be different.  If you understand how to make rollover/rollout code, then you should be able to read/follow either an AS2 or an AS3 tutorial.  IN any case, if you search using "AS2 animated button tutorial" there are several results that should be helpful to you.
                The basics of the scheme are that when you rollover the button (actually a movieclip) you trigger an animation within the button and when you rollout of the button you play the reverse of that animation.  You can do the animations as timeline animations or as coded animations.
                • 5. Re: mouse over effect
                  Here is a link to a sample file that shows the two different ways I mentioned it could be done.  There are other ways as well, but these should at least get you started.
                  http://www.nedwebs.com/Flash/AS2_Animated_Btns.fla
                  • 6. Re: mouse over effect
                    manojb05 Level 1
                    nedmurphy ur link is not working
                    • 7. Re: mouse over effect
                      Yes, it is working
                      • 8. Re: mouse over effect
                        manojb05 Level 1
                        i am click the link some code is come like this
                        ÐÏ à¡± á> þÿ        : þÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿRoot Entry  ÿÿÿÿÿÿÿÿ pª|YªrÏ ƒ RASH°ÌECõ Í < Contents   ÿÿÿÿÿÿÿÿÿÿÿÿKAIP 1 1332506058     ÿÿÿÿI S 2 1332506249     ÿÿÿÿB› ;ýÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿþÿÿÿ=>?@ABCDEFGHIJþÿÿÿLMNOPQRSTUVWXY Z[\]^_`abcdefghijklmnoþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Root Entry  ÿÿÿÿÿÿÿÿ pª|YªrÏ ƒ RASHP æïô Í   Contents   ÿÿÿÿÿÿÿÿÿÿÿÿ AIP 1 1332506058     ÿÿÿÿI S 2 1332506249     ÿÿÿÿB› ÿÿÿÿÿÿÿÿ ýÿÿÿþÿÿÿþÿÿÿ
                               þÿÿÿ           !"#$%&'()*+,-./0123456789þÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿS 1 1332506097  ÿÿÿÿÿÿÿÿÿÿÿÿ l S 3 1332506736  ÿÿÿÿÿÿÿÿÿÿÿÿä ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
                              þÿÿÿ            !"#$%&'()*+,-./0123456789:;<=>?@AþÿÿÿCDEFGHþÿÿÿJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrs tuvwþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame €€      ™fÿó ˜ è  ï<pþpþ 0P <   0à <  pþ0°ë<pþpþpþ    ÿÿÿ?ÿÿÿþÿ  ïuÿþÿÿþÿ  €€ ÿþÿ extended buttonÿÿÿÿ™3Ìÿ  €  € ÿÿ
                        CPicSprite   0ýÿÿ    T÷ÿÿ      ÿÿÿÿÿþÿ     I,ÿþÿÿþÿ msk    ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3.1'>
                        </component>
                        €€         ÿÿÿ?ÿÿÿþÿ  WFÿþÿÿþÿ  €€ ÿþÿ maskÿÿÿÿÿÿOÿ      €  € €€      ÿ ÿ    ÿó   @ ì0Àù0 0@     ÿÿÿ?ÿÿÿþÿ  a<ÿþÿÿþÿ  €€ ÿþÿ main button ÿÿÿÿOÿOÿ  €€    ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame €€      ™fÿó ˜ è  ï<pþpþ 0P <   0à <  pþ0°ë<pþpþpþ    ÿÿÿ?ÿÿÿþÿ  ÌHÿþÿÿþÿ  €€ ÿþÿ extended button ÿÿÿÿ™3Ìÿ  €  € ÿÿ
                        CPicSprite   0ýÿÿ    T÷ÿÿ      ÿÿÿÿÿþÿ     ¿`ÿþÿÿþÿ    ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
                        </component>
                        €€         ÿÿÿ?ÿÿÿþÿ  SWÿþÿÿþÿ   €      €   Р    ô       ÿÿÿÿÿþÿ     ¿ ÿþÿÿþÿ     ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.2'>
                        </component>
                        €€         ÿÿÿ?ÿÿÿþÿ  Ö<ÿþÿÿþÿ   €      €    0ýÿÿ    T÷ÿÿ      ÿÿÿÿÿþÿ     Öjÿþÿÿþÿ     ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
                        </component>
                        €€        ÿÿÿ?ÿÿÿþÿ   /ÿþÿÿþÿ  €€ ÿþÿ
                        animated mask ÿÿÿÿÿÿOÿ      €  € €€      ÿ ÿ    ÿó   @ ì0Àù0 0@     ÿÿÿ?ÿÿÿþÿ  ~ ÿþÿÿþÿ  €€ ÿþÿ main buttonÿÿÿÿOÿOÿ   €  € €€        ÿÿÿ?ÿÿÿþÿ  -Bÿþÿ stop();ÿþÿ   € €€        ÿÿÿ?ÿÿÿþÿ  ÜTÿþÿ stop();ÿþÿ   € €€        ÿÿÿ?ÿÿÿþÿ  Ž6ÿþÿ gotoAndStop(1);ÿþÿ  €€ ÿþÿ actions ÿÿÿÿÿOÿÿ  €€    ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame ÿÿ      CPicShape  €€   ìÿÿÿ þÿÿ   ™fÿó ˜ è  ï<pþpþ 0P <   0à <  pþ0°ë<pþpþpþ€€        ÿÿÿ?ÿÿÿþÿ  g\ÿþÿÿþÿ  €€ ÿþÿ Layer 1 ÿÿÿÿOÿOÿ   €€    ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame ÿÿ
                        CPicSprite ”      ” t           ÿÿÿÿÿþÿ     É#ÿþÿÿþÿ btn_timeline    ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1'>
                        </component>
                        €€     Ø h Ø h éêÿÿø éêÿÿø     ÿÿÿ?ÿÿÿþÿ  ê3ÿþÿÿþÿ  €€ ÿþÿ Layer 1ÿÿÿÿOÿOÿ    €  €  € •       Ž           ÿÿÿÿÿþÿ     ƒyÿþÿÿþÿ     btn_tween    ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3'>
                        </component>
                        €€        ÿÿÿ?ÿÿÿþÿ  f
                        ÿþÿÿþÿ  €€ ÿþÿ Layer 3ÿÿÿÿÿÿOÿ    €  € €€        ÿÿÿ?ÿÿÿþÿ  ÿ/ÿþÿÿ´ // here is the code for the button that has the animation built into it
                        btn_timeline.onRollOver = function(){
                        btn_timeline.gotoAndPlay(2);
                        btn_timeline.onRollOut = function(){
                        btn_timeline.gotoAndPlay(16);
                        // HEre is the code for the version where actionscript is used to animate the mask
                        import mx.transitions.Tween;
                        import mx.transitions.easing.Regular;
                        btn_tween.onRollOver = function(){
                        tweenTo(25);  // _ending _y value is 25
                        btn_tween.onRollOut = function(){
                        tweenTo(-111);  // _ending _y value is -111
                        var tw:Tween;
                        function tweenTo(yValue){
                        tw = new Tween(btn_tween.msk, "_y", Regular.easeIn, btn_tween.msk._y, yValue, 0.5, true);
                        ÿþÿ  €€ ÿþÿ Layer 2 ÿÿÿÿ™3Ìÿ   €€   ? ÿÿ
                        CDocumentPage  P 1 1332506058ÿþÿ Scene 1ÿþÿ    ÊmlO
                        ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ³slOÿþÿÿþÿ    ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ  ÿþÿÿþÿÿþÿ ÿþÿ€€€€    €  S 2 1332506249ÿþÿ Symbol 2  ÿþÿ    ‰nlO  ÿþÿÿþÿÿþÿ ÿþÿÿþÿ Symbol 2 ÿÿÿÿÿþÿ‰nlOÿþÿÿþÿ    ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ  ÿþÿÿþÿÿþÿÿþÿ€€€€ €  S 1 1332506097ÿþÿ Symbol 1  ÿþÿ    ñmlO  ÿþÿÿþÿÿþÿ ÿþÿÿþÿ Symbol 1 ÿÿÿÿÿþÿ‡olOÿþÿÿþÿ    ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ  ÿþÿÿþÿÿþÿ ÿþÿ€€€€ €  S 3 1332506736ÿþÿ Symbol 3  ÿþÿ    pplO
                        ÿþÿÿþÿÿþÿ ÿþÿÿþÿ
                        Symbol 1 copy ÿÿÿÿÿþÿ–qlOÿþÿÿþÿ   ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ ÿþÿÿþÿÿþÿÿþÿ€€€€   ø*@ h  h h h h    ÿÿÿÿÀÀÀÿ  ´ ÿþÿ legacyLineSpacingÿþÿ 0 ¢ÿþÿ%PublishFormatProperties::htmlFileNameÿþÿ Untitled-1.htmlÿþÿ"PublishHtmlProperties::StartPausedÿþÿ 0ÿþÿ Vector::AS3 Package Pathsÿþÿÿþÿ PublishRNWKProperties::speed256Kÿþÿ 0ÿþÿ!PublishGifProperties::PaletteNameÿþÿÿþÿ PublishFormatProperties::jpegÿþÿ 0ÿþÿ PublishHtmlProperties::Loopÿþÿ 1ÿþÿ PublishProfileProperties::nameÿþÿ Defaultÿþÿ Vector::Debugging Permittedÿþÿ 0ÿþÿ Vector::UseNetworkÿþÿ 0ÿþÿ"PublishQTProperties::MatchMovieDimÿþÿ 1ÿþÿ PublishQTProperties::AlphaOptionÿþÿÿþÿ PublishQTProperties::LayerOptionÿþÿÿþÿ4PublishHtmlProperties::UsingDefaultAlternateFilena meÿþÿ 1ÿþÿ PublishHtmlProperties::Unitsÿþÿ 0ÿþÿ%PublishHtmlProperties::showTagWarnMsgÿþÿ 1ÿþÿ Vector::External Playerÿþÿÿþÿ Vector::DocumentClassÿþÿÿþÿ&PublishRNWKProperties::singleRateAudioÿþÿ 0ÿþÿ&PublishRNWKProperties::speedSingleISDNÿþÿ 0ÿþÿ$PublishPNGProperties::OptimizeColorsÿþÿ 1ÿþÿ PublishQTProperties::Widthÿþÿ 550ÿþÿ%PublishFormatProperties::projectorMacÿþÿ 0ÿþÿ'PublishFormatProperties::gifDefaultNameÿþÿ 1ÿþÿ&PublishFormatProperties::flashFileNameÿþÿ Untitled-1.swfÿþÿ Vector::Package Pathsÿþÿÿþÿ Vector::Compress Movieÿþÿ 1ÿþÿ Vector::ScriptStuckDelayÿþÿ 15ÿþÿ#PublishRNWKProperties::flashBitRateÿþÿ 1200ÿþÿ%PublishRNWKProperties::mediaCopyrightÿþÿ (c) 2000ÿþÿ PublishGifProperties::Smoothÿþÿ 1ÿþÿ PublishFormatProperties::htmlÿþÿ 1ÿþÿ$PublishFormatProperties::pngFileNameÿþÿ Untitled-1.pngÿþÿ(PublishHtmlProperties::VerticalAlignmentÿþÿ 1ÿþÿ PublishHtmlProperties::Qualityÿþÿ 4ÿþÿ Vector::FireFoxÿþÿ 0ÿþÿ Vector::Invisible Layerÿþÿ 1ÿþÿ Vector::AS3ExportFrameÿþÿ 1ÿþÿ"PublishRNWKProperties::exportAudioÿþÿ 1ÿþÿ PublishRNWKProperties::speed384Kÿþÿ 0ÿþÿ!PublishRNWKProperties::exportSMILÿþÿ 1ÿþÿ"PublishGifProperties::DitherOptionÿþÿÿþÿ-PublishFormatProperties::generatorDefaultNa meÿþÿ 1ÿþÿ!PublishHtmlProperties::DeviceFontÿþÿ 0ÿþÿ Vector::Override Soundsÿþÿ 0ÿþÿ'PublishRNWKProperties::mediaDescriptionÿþÿÿþÿ"PublishPNGProperties::FilterOptionÿþÿÿ þÿ PublishFormatProperties::gifÿþÿ 0ÿþÿ(PublishFormatProperties::jpegDefaultNameÿþÿ 1ÿþÿ(PublishFormatProperties::rnwkDefaultNameÿþÿ 1ÿþÿ*PublishFormatProperties::generatorFileNameÿþÿ Untitled-1.swtÿþÿ Vector::Templateÿþÿ 0ÿþÿ2PublishHtmlProperties::VersionDetectionIfAvailableÿþÿ 0ÿþÿ*PublishHtmlProperties::HorizontalAlignmentÿþÿ 1ÿþÿ"PublishHtmlProperties::DisplayMenuÿþÿ 1ÿþÿ Vector::Protectÿþÿ 0ÿþÿ Vector::Qualityÿþÿ 80ÿþÿ PublishJpegProperties::DPIÿþÿ 4718592ÿþÿ PublishGifProperties::Interlaceÿþÿ 0ÿþÿ"PublishGifProperties::DitherSolidsÿþÿ 0ÿþÿ PublishPNGProperties::Smoothÿþÿ 1ÿþÿ PublishPNGProperties::BitDepthÿþÿ 24-bit with Alphaÿþÿ PublishQTProperties::Flattenÿþÿ 1ÿþÿ#PublishFormatProperties::qtFileNameÿþÿ Untitled-1.movÿþÿ Vector::AS3Optimizeÿþÿ 1ÿþÿ PublishRNWKProperties::speed28Kÿþÿ 1ÿþÿ!PublishRNWKProperties::mediaTitleÿþÿÿþÿ$PublishRNWKProperties::mediaKeywordsÿþÿÿþÿ PublishGifProperties::Widthÿþÿ 550ÿþÿ PublishGifProperties::Loopÿþÿ 1ÿþÿ PublishFormatProperties::flashÿþÿ 1ÿþÿ PublishJpegProperties::Qualityÿþÿ 80ÿþÿ$PublishRNWKProperties::realVideoRateÿþÿ 100000ÿþÿ$PublishRNWKProperties::speedDualISDNÿþÿ 0ÿþÿ#PublishGifProperties::MatchMovieDimÿþÿ 1ÿþÿ#PublishGifProperties::PaletteOptionÿþÿÿþÿ"PublishPNGProperties::DitherOptionÿþÿÿþÿ0P ublishFormatProperties::projectorMacDefaultNameÿþÿ 1ÿþÿ'PublishFormatProperties::pngDefaultNameÿþÿ 1ÿþÿ-PublishFormatProperties::projectorWinFileNameÿþÿ Untitled-1.exeÿþÿ PublishHtmlProperties::Alignÿþÿ 0ÿþÿ!PublishProfileProperties::versionÿþÿ 1ÿþÿ Vector::Package Export Frameÿþÿ 1ÿþÿ$PublishJpegProperties::MatchMovieDimÿþÿ 1ÿþÿ#PublishPNGProperties::MatchMovieDimÿþÿ 1ÿþÿ#PublishPNGProperties::PaletteOptionÿþÿÿþÿ)PublishFormatProperties::flashDefaultNameÿ þÿ 1ÿþÿ%PublishFormatProperties::jpegFileNameÿþÿ Untitled-1.jpgÿþÿ PublishHtmlProperties::Widthÿþÿ 550ÿþÿ PublishHtmlProperties::Heightÿþÿ 400ÿþÿ Vector::Omit Trace Actionsÿþÿ 0ÿþÿ Vector::Debugging Passwordÿþÿÿþÿ Vector::Export Swcÿþÿ 0ÿþÿ"PublishJpegProperties::Progressiveÿþÿ 0ÿþÿ"PublishPNGProperties::DitherSolidsÿþÿ 0ÿþÿ#PublishQTProperties::PlayEveryFrameÿþÿ 0ÿþÿ PublishFormatProperties::pngÿþÿ 0ÿþÿ PublishFormatProperties::rnwkÿþÿ 0ÿþÿ(PublishFormatProperties::htmlDefaultNameÿþÿ 1ÿþÿ-PublishFormatProperties::projectorMacFileNameÿþÿ Untitled-1.hqxÿþÿ2PublishHtmlProperties::UsingDefaultContentFilenameÿþÿ 1ÿþÿ!PublishHtmlProperties::WindowModeÿþÿ 0ÿþÿ'PublishHtmlProperties::TemplateFileNameÿþÿ Default.htmlÿþÿ Vector::TopDownÿþÿ 0ÿþÿ Vector::DeviceSoundÿþÿ 0ÿþÿ Vector::AS3Coachÿþÿ 1ÿþÿ Vector::AS3AutoDeclareÿþÿ 1ÿþÿ Vector::UseAS3Namespaceÿþÿ 1ÿþÿ PublishJpegProperties::Sizeÿþÿ 0ÿþÿ PublishGifProperties::Heightÿþÿ 400ÿþÿ PublishPNGProperties::Interlaceÿþÿ 0ÿþÿ"PublishFormatProperties::generatorÿþÿ 0ÿþÿ&PublishHtmlProperties::ContentFilenameÿþÿÿþÿ(PublishHtmlProperties::AlternateFilenam eÿþÿÿþÿ+PublishHtmlProperties::OwnAlternateFilenameÿþÿÿþÿ Vector::Reportÿþÿ 0ÿþÿ PublishRNWKProperties::speed56Kÿþÿ 1ÿþÿ PublishGifProperties::LoopCountÿþÿÿþÿ'PublishGifProperties::TransparentOptionÿþÿÿþÿ PublishGifProperties::MaxColorsÿþÿ 255ÿþÿ%PublishPNGProperties::RemoveGradientsÿþÿ 0ÿþÿ PublishQTProperties::Heightÿþÿ 400ÿþÿ PublishFormatProperties::qtÿþÿ 0ÿþÿ Vector::Stream Compressÿþÿ 7ÿþÿ Vector::Event Formatÿþÿ 0ÿþÿ Vector::Versionÿþÿ 8ÿþÿ Vector::AS3Strictÿþÿ 1ÿþÿ"PublishRNWKProperties::audioFormatÿþÿ 0ÿþÿ$PublishGifProperties::OptimizeColorsÿþÿ 1ÿþÿ0PublishFormatProperties::projectorWinDefaultNameÿþÿ 1ÿþÿ PublishHtmlProperties::Scaleÿþÿ 0ÿþÿ Vector::Event Compressÿþÿ 7ÿþÿ Vector::ActionScriptVersionÿþÿ 2ÿþÿ Vector::StreamUse8kSampleRateÿþÿ 0ÿþÿ Vector::EventUse8kSampleRateÿþÿ 0ÿþÿ PublishJpegProperties::Heightÿþÿ 400ÿþÿ PublishRNWKProperties::speed512Kÿþÿ 0ÿþÿ%PublishGifProperties::RemoveGradientsÿþÿ 0ÿþÿ PublishPNGProperties::Widthÿþÿ 550ÿþÿ PublishPNGProperties::Heightÿþÿ 400ÿþÿ&PublishFormatProperties::qtDefaultNameÿþÿ 1ÿþÿ$PublishFormatProperties::gifFileNameÿþÿ Untitled-1.gifÿþÿ"PublishHtmlProperties::VersionInfoÿþÿP9,0,115,0;8,0,24,0;7,0,14,0;6,0,7 9,0;5,0,58,0;4,0,32,0;3,0,8,0;2,0,1,12;1,0,0,1;ÿþÿ Vector::Stream Formatÿþÿ 0ÿþÿ PublishJpegProperties::Widthÿþÿ 550ÿþÿ"PublishRNWKProperties::exportFlashÿþÿ 1ÿþÿ&PublishRNWKProperties::showBitrateDlogÿþÿ 1ÿþÿ(PublishRNWKProperties::speedCorporateLANÿþÿ 0ÿþÿ"PublishRNWKProperties::mediaAuthorÿþÿÿþÿ PublishGifProperties::Animatedÿþÿ 0ÿþÿ&PublishGifProperties::TransparentAlphaÿþÿ 128ÿþÿ!PublishPNGProperties::Transparentÿþÿ 0ÿþÿ!PublishPNGProperties::PaletteNameÿþÿÿþÿ*PublishQTProperties::UseQTSoundCompressionÿþ ÿ 0ÿþÿ PublishQTProperties::Loopingÿþÿ 0ÿþÿ%PublishFormatProperties::defaultNamesÿþÿ 1ÿþÿ%PublishFormatProperties::projectorWinÿþÿ 0ÿþÿ%PublishFormatProperties::rnwkFileNameÿþÿ Untitled-1.smilÿþÿ,PublishHtmlProperties::UsingOwnAlternateFileÿþÿ 0ÿþÿ PublishPNGProperties::MaxColorsÿþÿ 255ÿþÿ%PublishQTProperties::ControllerOptionÿþÿ 0ÿþÿ"PublishQTProperties::PausedAtStartÿþÿ 0ÿÿÿÿÿþÿÿþÿ üÿÿ     CColorDef ÿ € ÿ € ÿ € ÿ € 3ÿPï  € fÿPï0 € ™ÿPïH € ÌÿPï` € ÿÿPïx € 3ÿï  € 33ÿ(ï  € 3fÿ<ï0 € 3™ÿCïH € 3ÌÿFï` € 3ÿÿHïx € fÿï0 € f3ÿ ï0 € ffÿ(ï0 € f™ÿ5ïH € fÌÿ<ï` € fÿÿ@ïx € ÿ € 333ÿ0 € ÿ € 3ÿ ï  € 33ÿxï  € f3ÿdï0 € ™3ÿ]ïH € Ì3ÿZï` € ÿ3ÿXïx € 33ÿÈï  € 333ÿ0 € 3f3ÿPPH € 3™3ÿPx` € 3Ì3ÿPx € 3ÿ3ÿPï € f3ÿÜï0 € f33ÿPH € ff3ÿ(PH € f™3ÿ<x` € fÌ3ÿCx € fÿ3ÿFï € ÿ € fffÿ` € ÿ € fÿ ï0 € 3fÿŒï0 € ffÿxï0 € ™fÿkïH € Ìfÿdï` € ÿfÿ`ïx € 3fÿ´ï0 € 33fÿ PH € 3ffÿxPH € 3™fÿdx` € 3Ìfÿ]x € 3ÿfÿZï € ffÿÈï0 € f3fÿÈPH € fffÿ` € f™fÿP0x € fÌfÿPx € fÿfÿPï¨ € ÿ € ™™™ÿ € ÿ € ™ÿ ïH € 3™ÿ“ïH € f™ÿ…ïH € ™™ÿxïH € Ì™ÿnï` € ÿ™ÿhïx € 3™ÿïH € 33™ÿ x` € 3f™ÿŒx` € 3™™ÿxx` € 3Ì™ÿkx € 3ÿ™ÿdï € f™ÿ»ïH € f3™ÿ´x` € ff™ÿ 0x € f™™ÿx0x € fÌ™ÿdx € fÿ™ÿ]ï¨ € ÿ € ÌÌÌÿÀ € ÿ € Ìÿ ï` € 3Ìÿ–ï` € fÌÿŒï` € ™Ìÿ‚ï` € ÌÌÿxï` € ÿÌÿpïx € 3Ìÿªï` € 33Ìÿ x € 3fÌÿ“x € 3™Ìÿ…x € 3ÌÌÿxx € 3ÿÌÿnï € fÌÿ´ï` € f3Ìÿx € ffÌÿ x € f™ÌÿŒx € fÌÌÿxx € fÿÌÿkï¨ € ÿ € ÿÿÿÿð € ÿ € ÿÿ ïx € 3ÿÿ˜ïx € fÿÿïx € ™ÿÿˆïx € Ìÿÿ€ïx € ÿÿÿxïx € 3ÿÿ¨ïx € 33ÿÿ ï € 3fÿÿ–ï € 3™ÿÿŒï € 3Ìÿÿ‚ï € 3ÿÿÿxï € fÿÿ°ïx € f3ÿÿªï € ffÿÿ ï¨ € f™ÿÿ“ï¨ € fÌÿÿ…ï¨ € fÿÿÿxï¨ € ÿ € ÿÿïx € ÿ € ™ÿïH € ™3ÿ
                        ïH € ™fÿ ïH € ™™ÿ(ïH € ™Ìÿ2ï` € ™ÿÿ8ïx € Ìÿï` € Ì3ÿ
                        ï` € Ìfÿ ï` € Ì™ÿ ï` € ÌÌÿ(ï` € Ìÿÿ0ïx € ÿÿïx € ÿ3ÿ ïx € ÿfÿ ïx € ÿ™ÿ ïx € ÿÌÿ ïx € ÿÿÿ(ïx € ÿ € ÿÿPïx € ÿ € ™3ÿãïH € ™33ÿx` € ™f3ÿ x` € ™™3ÿ(x` € ™Ì3ÿ5x € ™ÿ3ÿ<ï € Ì3ÿæï` € Ì33ÿx € Ìf3ÿ
                        x € Ì™3ÿ x € ÌÌ3ÿ(x € Ìÿ3ÿ2ï € ÿ3ÿèïx € ÿ33ÿï € ÿf3ÿ
                        ï € ÿ™3ÿ ï € ÿÌ3ÿ ï € ÿÿ3ÿ(ï € ÿ € ÿÿ ïx € ÿ € ™fÿÕïH € ™3fÿÜx` € ™ffÿ0x € ™™fÿ(0x € ™Ìfÿ<x € ™ÿfÿCï¨ € ÌfÿÜï` € Ì3fÿãx € Ìffÿx € Ì™fÿ x € ÌÌfÿ(x € Ìÿfÿ5ï¨ € ÿfÿàïx € ÿ3fÿæï € ÿffÿï¨ € ÿ™fÿ
                        ï¨ € ÿÌfÿ ï¨ € ÿÿfÿ(ï¨ € ÿ € ÿÿÿ(ïx € ÿ € ™™ÿÈïH € ™3™ÿÈx` € ™f™ÿÈ0x € ™™™ÿ € ™Ì™ÿPP¨ € ™ÿ™ÿPïÀ € Ì™ÿÒï` € Ì3™ÿՐx € Ìf™ÿÜx € Ì™™ÿP¨ € ÌÌ™ÿ(P¨ € Ìÿ™ÿ<ïÀ € ÿ™ÿØïx € ÿ3™ÿÜï € ÿf™ÿãï¨ € ÿ™™ÿïÀ € ÿÌ™ÿ ïÀ € ÿÿ™ÿ(ïÀ € ÿ € ÿÿÿxïx € ÿ € ™Ìÿ¾ï` € ™3Ìÿ»x € ™fÌÿ´x € ™™Ìÿ P¨ € ™ÌÌÿxP¨ € ™ÿÌÿdïÀ € ÌÌÿÈï` € Ì3ÌÿȐx € ÌfÌÿÈx € Ì™ÌÿÈP¨ € ÌÌÌÿÀ € ÌÿÌÿPïØ € ÿÌÿÐïx € ÿ3ÌÿÒï € ÿfÌÿÕï¨ € ÿ™ÌÿÜïÀ € ÿÌÌÿïØ € ÿÿÌÿ(ïØ € ÿ € ÿÿÿÈïx € ÿ € ™ÿÿ¸ïx € ™3ÿÿ´ï € ™fÿÿï¨ € ™™ÿÿ ïÀ € ™ÌÿÿŒïÀ € ™ÿÿÿxïÀ € ÌÿÿÀïx € Ì3ÿÿ¾ï € Ìfÿÿ»ï¨ € Ì™ÿÿ´ïÀ € ÌÌÿÿ ïØ € ÌÿÿÿxïØ € ÿÿÿÈïx € ÿ3ÿÿÈï € ÿfÿÿÈï¨ € ÿ™ÿÿÈïÀ € ÿÌÿÿÈïØ € ÿÿÿÿð  € ÿ    ÿÿÿÿÿÿ € ÿ    ÿÿÿÿÿÿ € ÿ    ÿÿÿÿ € ÿ    ÿÿÿÿ € ÿ    ÿÿÿÿ € ÿ    fýÿ`ÿÿÿÿzÿÿÿÿ€™fÿªÿÌÿÿÿÿÿÿ € ÿ    ÿÿ*ÿÿÿ]ÿÿÿÿÿªÿÿÔÿÿÿÿÿÿ  ý ˆ ¤ z     ÿþÿ"PublishQTProperties::QTSndSettingsÿÿ  CQTAudioSettings ÿÿ  ÿþÿ   h ÿþÿÿþÿ      ÿÿÿÿÿþÿ ÿþÿÿþÿÿþÿÿÿÿÿÿÿÿÿ     î BSaved by Adobe Flash Windows 9.0 build 494 timecount = 1332507635
                              þÿÿÿ            !"#$%&'()*+,-./0123456789:;<=>?@AþÿÿÿCDEFGHþÿÿÿJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrs tuvwþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿS 1 1332506097  ÿÿÿÿÿÿÿÿÿÿÿÿ l S 3 1332506736  ÿÿÿÿÿÿÿÿÿÿÿÿä ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame €€      ™fÿó ˜ è  ï<pþpþ 0P <   0à <  pþ0°ë<pþpþpþ    ÿÿÿ?ÿÿÿþÿ  < ÿþÿÿþÿ  €€ ÿþÿ extended buttonÿÿÿÿ™3Ìÿ  €  € ÿÿ
                        CPicSprite   0ýÿÿ    T÷ÿÿ      ÿÿÿÿÿþÿ      9ÿþÿÿþÿ msk    ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3.1'>
                        </component>
                        €€         ÿÿÿ?ÿÿÿþÿ  ‡~ÿþÿÿþÿ  €€ ÿþÿ maskÿÿÿÿÿÿOÿ      €  € €€      ÿ ÿ    ÿó   @ ì0Àù0 0@     ÿÿÿ?ÿÿÿþÿ  > ÿþÿÿþÿ  €€ ÿþÿ main button ÿÿÿÿOÿOÿ  €€    ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame €€      ™fÿó ˜ è  ï<pþpþ 0P <   0à <  pþ0°ë<pþpþpþ    ÿÿÿ?ÿÿÿþÿ  l=ÿþÿÿþÿ  €€ ÿþÿ extended button ÿÿÿÿ™3Ìÿ  €  € ÿÿ
                        CPicSprite   0ýÿÿ    T÷ÿÿ      ÿÿÿÿÿþÿ     ®rÿþÿÿþÿ    ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
                        </component>
                        €€         ÿÿÿ?ÿÿÿþÿ  Ö,ÿþÿÿþÿ   €      €   Р    ô       ÿÿÿÿÿþÿ     I ÿþÿÿþÿ     ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.2'>
                        </component>
                        €€         ÿÿÿ?ÿÿÿþÿ  _ÿþÿÿþÿ   €      €    0ýÿÿ    T÷ÿÿ      ÿÿÿÿÿþÿ     ñZÿþÿÿþÿ     ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
                        </component>
                        €€        ÿÿÿ?ÿÿÿþÿ  ñmÿþÿÿþÿ  €€ ÿþÿ
                        animated mask ÿÿÿÿÿÿOÿ      €  € €€      ÿ ÿ    ÿó   @ ì0Àù0 0@     ÿÿÿ?ÿÿÿþÿ  »Aÿþÿÿþÿ  €€ ÿþÿ main buttonÿÿÿÿOÿOÿ   €  € €€        ÿÿÿ?ÿÿÿþÿ  é&ÿþÿ stop();ÿþÿ   € €€        ÿÿÿ?ÿÿÿþÿ  ë ÿþÿ stop();ÿþÿ   € €€        ÿÿÿ?ÿÿÿþÿ  ³ ÿþÿ gotoAndStop(1);ÿþÿ  €€ ÿþÿ actions ÿÿÿÿÿOÿÿ  €€    ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame ÿÿ      CPicShape  €€   ìÿÿÿ þÿÿ   ™fÿó ˜ è  ï<pþpþ 0P <   0à <  pþ0°ë<pþpþpþ€€        ÿÿÿ?ÿÿÿþÿ  Riÿþÿÿþÿ  €€ ÿþÿ Layer 1 ÿÿÿÿOÿOÿ   €€    ÿÿ  CPicPage ÿÿ      CPicLayer ÿÿ      CPicFrame ÿÿ
                        CPicSprite ”      ” t           ÿÿÿÿÿþÿ     áJÿþÿÿþÿ btn_timeline    ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1'>
                        </component>
                        €€     Ø h Ø h éêÿÿø éêÿÿø     ÿÿÿ?ÿÿÿþÿ  „gÿþÿÿþÿ  €€ ÿþÿ Layer 1ÿÿÿÿOÿOÿ    €  €  € •       Ž           ÿÿÿÿÿþÿ     Û ÿþÿÿþÿ     btn_tween    ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3'>
                        </component>
                        €€        ÿÿÿ?ÿÿÿþÿ  ¦.ÿþÿÿþÿ  €€ ÿþÿ Layer 3ÿÿÿÿÿÿOÿ    €  € €€        ÿÿÿ?ÿÿÿþÿ  ™ÿþÿÿ´ // here is the code for the button that has the animation built into it
                        var tw:Tween;
                        • 9. Re: mouse over effect
                          I can't help you there.  The link works fine and the file I get opens fine.
                          • 10. Re: mouse over effect
                            manojb05 Level 1
                            ok its working i want also link a html page link to buttons
                            • 11. Re: mouse over effect
                              Look up the getURL() function
                              • 12. Re: mouse over effect
                                manojb05 Level 1
                                ned murphy where i incorporate in getURL please help this?
                                • 13. Re: mouse over effect
                                  In an onRelease function, similare to the rollover and rollout
                                  yourBtn.onRelease = function(){
                                      getURL(http://www...);
                                  • 14. Re: mouse over effect
                                    manojb05 Level 1
                                    as per your yesterday mail button name is "btn_timeline" can i change & place it
                                    • 15. Re: mouse over effect
                                      You can change it to suit your needs.
                                      • 16. Re: mouse over effect
                                        manojb05 Level 1
                                        dear nedmurphy some error is come out, jpg file is attached is your reference
