1 Reply Latest reply on Apr 22, 2008 3:47 AM by SujitG
    Using two panels with different colors ???
    aktell2007 Level 1
      Hi there,
      I’m running into problems with my app. Please can somebody give some advice?
      I’m using a normal standard namespace (mx:Panel) component and a Skin in the whole app. Now I require to use another (mx:Panel) component and this has to have another color from the first Panel.
      Thanks in advance aktell
        • 1. Re: Using two panels with different colors ???
          SujitG Level 2
          If you set the style properties for the Panel you want to modify, it will consider the properties you set than loading from the global css file. I have created a sample in which i have two Accordions, in which one Accordion uses the global style for the header and other one uses the style which i set for that Accordion.
          Hope this helps
