7 Replies Latest reply on Mar 25, 2012 11:41 AM by robdillon
    fl_ProLoader Help
    AlexanderKaran
      I was wondering if i could just ask for you help o this thing i am doing in
      flash as i cant get the code to work, i need to swf file to unload when i
      press any key on the keyboard
      So when your on frame 30 you click an image and it takes you to frame 35 and
      load the video in a container with this code
      movie1_btn.addEventListener(MouseEvent.CLICK, fl_ClickToLoadUnloadSWF);
      import fl.display.ProLoader;
      var fl_ProLoader:ProLoader;
      var fl_ToLoad:Boolean = true;
      function fl_ClickToLoadUnloadSWF(event:MouseEvent):void
        if(fl_ToLoad)
            fl_ProLoader = new ProLoader();
            fl_ProLoader.load(new URLRequest("Movie1-FullVersion.swf"));
            gotoAndStop(35);
            preholder.addChild(fl_ProLoader);
        else
            fl_ProLoader.unload();
            removeChild(fl_ProLoader);
            fl_ProLoader = null;
        fl_ToLoad = !fl_ToLoad;
      Then when your on frame 35 you press any keyboard key to return to frame 30
      but i cant get the code right so that it also unload the swf file
      here is the code i use to return
      stage.addEventListener(KeyboardEvent.KEY_DOWN, fl_KeyboardDownHandler);
      function fl_KeyboardDownHandler(event:KeyboardEvent):void
        trace("Key Code Pressed: " + event.keyCode);
        gotoAndStop (30);
      what code do i need to put in there to unload?
      Please help as i am really stuck on this and its giving me a headache, iv
      tried so many combinations
      Thank you
      Alexander
