0 Replies Latest reply on Apr 14, 2008 6:52 AM by AHDev
    Symlink Issue
    AHDev
      Hi
      I have recently upgraded a project from CFMX7 to CF8. The problem I'm having is that I have a number of subdomains which are setup. Each of these subdomains contains an Application file at the root, and a folder called administration. This folder is a symlink which has been setup which links to the physical files.
      If I try and view a login.cfm page with the administration folder (i.e. http://test.domain.com/administration/login.cfm), an error message comes up which says that my application variables are not defined. This directory seems to have an issue locating the Application file in the directory above. Has anyone experienced the same error at all? I've read that CF8 has issues with symlinks.
      Thanks for your help - it would really be appreciated!!
      Aileen
