1 Reply Latest reply on Mar 24, 2012 11:00 AM by Ned Murphy
    Text displays in wrong size
    Welshy 2008 Level 1
      I'm working on a Flash presentation, and I have a lot of text pages with buttons and movie clips on. The problem I have is that all subheads are set to size 35pt using Helvetica Neue Heavy, but on a couple of the pages a random subhead is displaying a lot larger than 35pt (I'd say 50pt) but it is definitely set to size 35pt in the Character palette. I have no idea why this is happening and it's driving me mad. Please can someone help me, I need to get this problem solved by Monday?
      Kind regards
        • 1. Re: Text displays in wrong size
          If the text is assigned as the correct size, then it might be a case where you have something that contains the text scaled larger.  You could try selecting the text or whatever contains it and then in the top menu choose Modify -> Reome Transform and see if that helps (might need to do it a couple times)
