6 Replies Latest reply: Mar 27, 2012 5:35 AM by Wight-Walker RSS
    LongSideResize.jsx not working correctly
    Wight-Walker Community Member
      I downloaded this script from Adobe which I've used in CS5 as batch process to resize all files from 1631x1080 down to longside of 900px i.e 900x596.
      Using the same script in CS6 beta actually increases the size considerably i.e 25512x16893 from 1631x1080.
      Any ideas?
        • 1. Re: LongSideResize.jsx not working correctly
          R_Kelly Community Member
          Do you have a link to the script?
          • 2. Re: LongSideResize.jsx not working correctly
            You'll find the download @ http://www.adobe.com/cfusion/exchange/index.cfm?event=dl&extid=1044732
            Here's the code:
              if (!app.documents.length > 0) {
               alert("No active document");
              else {
                //Change this value to how long you would like the longest side to be
            var longSide = 500;
               var docRef = app.activeDocument;
               var docWidth = docRef.width.as("px");
               var docHeight = docRef.height.as("px");
               //if image is horizontal, resize with width being biggest parameter
               if (docWidth > docHeight)
                var multiplier = longSide/docWidth;
              docRef.resizeImage(longSide, docHeight*multiplier, 72, ResampleMethod.BICUBIC );
               else
                var multiplier = longSide/docHeight;
                docRef.resizeImage(docWidth*multiplier, longSide, 72, ResampleMethod.BICUBIC );
            I slightly modified the code to allow images greater that 1900px to be left at their default size:
            var longSide = 900;
            if (docWidth > 1900) {
              else {
              docRef.resizeImage(longSide, docHeight*multiplier, 72, ResampleMethod.BICUBICSHARPER );
               else
                docRef.resizeImage(docWidth*multiplier, longSide, 72, ResampleMethod.BICUBICSHARPER );
            Both scripts resize UP in CS6 beta whereas in CS5 they resize DOWN correctly to 900x900.
            • 3. Re: LongSideResize.jsx not working correctly
              In cs6 try setting your ruler units to pixels and see if the scripts work.
              If they do then add these lines to the top of the script:
              var originalUnit = app.preferences.rulerUnits;
              app.preferences.rulerUnits = Units.PIXELS;
              And add this line to the bottom of the script:
              app.preferences.rulerUnits = originalUnit;
              Also you can use the File>Scripts> Image Processor or Automate>Fit Image to do the same thing.
              • 4. Re: LongSideResize.jsx not working correctly
                Thanks, that works perfectly.
                I don't think that using the Image Processor would help.
                As part of editing imges for web publishing, I initially create post processed images that fit the resolution of my monitor, this mixture of images i.e. portrait (1080x1631), landscape (1631x1080) & panoramic (1920xwhatever) are then further reduced to portrait (596x900), landscape (900x596) & panoramic (1920xwhatever) at reduced file size.
                This simple script file allows me to include it in a batch process that handles the mixture of sizes.
                • 5. Re: LongSideResize.jsx not working correctly
                  If for example you wanted to resize the images with the long side at 900 px, using Automate>Fit Image you would enter 900 into both fields.
                  And for the image processor it would be the same:
                  • 6. Re: LongSideResize.jsx not working correctly
                    Have used this & it works fine on images that are 'x' by 'y' and/or 'y' by 'x' but the script files also allows me process a 3rd size differently in just the one process.
