2 Replies Latest reply on Mar 25, 2012 10:32 PM by zink07
    Reverse an Image
    zink07
      Can I reverse an image that has been transferred to digital reversed (i.e. Slide reversed and transferred)?  I'm using Elements 10 and am a complete newbie.
        • 1. Re: Reverse an Image
          Noel Carboni Level 8
          By the way, this is the Photoshop (full version) forum.  The Elements forum is a bit down the hall:  http://forums.adobe.com/community/photoshop_elements
          Reverse how?  Left to right / up to down, or negative?
          Both should be easily doable.  This is how you'd do them in Photoshop (full version):
          Image - Image Rotation - Flip Canvas ... will do the former.
          Image - Adjustments - Invert will do the latter.
          -Noel
          • 2. Re: Reverse an Image
            zink07 Level 1
            Thank you, Noel.  I will move to the Elements forum.  I was referring to a slide image that was transferred as a mirror image. (Print reversed, etc.).  I'd like to simply flip the image back to front to avoid having to have it transferred again.  Sounds like that's not possible with E10.  Thanks again.
            TED
