2 Replies Latest reply on Mar 28, 2012 5:02 AM by DavidKomer
    CloudFiles, Akamai, SMIL
    DavidKomer
      I've been looking through the plugin example, older OSMF examples, etc. and I haven't yet been able to piece together a working player which uses SMIL and the Akamai HDNetwork (via Rackspace Cloudfiles).
      The SMIL file does play properly when tested via flowplayer or my old custom-built version, which used HDCore.
      Here's the basic code I've tried, to no avail:
      package
                import com.akamai.osmf.AkamaiBasicStreamingPluginInfo;
                import flash.display.Sprite;
                import flash.events.EventDispatcher;
                import org.osmf.containers.MediaContainer;
                import org.osmf.elements.VideoElement;
                import org.osmf.events.MediaFactoryEvent;
                import org.osmf.media.DefaultMediaFactory;
                import org.osmf.media.MediaElement;
                import org.osmf.media.MediaFactory;
                import org.osmf.media.MediaPlayer;
                import org.osmf.media.MediaResourceBase;
                import org.osmf.media.PluginInfo;
                import org.osmf.media.PluginInfoResource;
                import org.osmf.media.URLResource;
                import org.osmf.net.DynamicStreamingResource;
                public class VP_REGULAR extends Sprite
                          private var mediaContainer:MediaContainer = null;
                          private var mediaPlayer:MediaPlayer = null;
                          private var smilLoader:SmilLoader = null;
                          private var mediaElement:MediaElement = null;
                          public function VP_REGULAR()
                                    super();
        //this.src = "http://c11412232.r32.stream.cf2.rackcdn.com/test/mbrtest/makingfriends_trailer_akamai_h264 _768x432_800kbps.mp4";
        this.src = "http://localhost/SimplePlayer/test.smil";
                          public function set src(str:String) {
        //Clear existing
                                    stop();
                                    mediaPlayer = null;
                                    if(mediaContainer != null) {
                                              removeChild(mediaContainer);
                                    mediaContainer = null;
                                    mediaElement = null;
                                    if(smilLoader != null) {
                                              smilLoader.removeEventListener(ObjEvent.COMPLETE, smilLoaded);
                                              smilLoader.close();
                                              smilLoader = null;
                                    if(str.indexOf('.smil') == -1) {
                                              loadSingleMedia(str);
                                    } else {
                                              loadSmil(str);
                          public function stop() {
                                    if(mediaPlayer != null) {
                                              mediaPlayer.stop();
                          private function loadSingleMedia(str:String) {
                                    var mediaFactory:MediaFactory = new DefaultMediaFactory();
                                    var mediaResource:URLResource = new URLResource(str);
                                    mediaElement = mediaFactory.createMediaElement(mediaResource);
                                    playMediaElement();
                          private function loadSmil(str:String) {
                                    smilLoader = new SmilLoader();
                                    smilLoader.addEventListener(ObjEvent.COMPLETE, smilLoaded);
                                    smilLoader.load(str);
                          private function smilLoaded(evt:ObjEvent) {
        trace('SMIL LOADED!');
                                    mediaElement = new VideoElement(evt.obj.resource);
                                    loadAkamaiPlugin();
                          private function loadAkamaiPlugin():void
                                    var pluginResource:MediaResourceBase = new PluginInfoResource(new AkamaiBasicStreamingPluginInfo());
                                    mediaFactory.addEventListener(MediaFactoryEvent.PLUGIN_LOAD, onAkamaiPluginLoaded);
                                    mediaFactory.loadPlugin(pluginResource);
                          private function onAkamaiPluginLoaded(evt:MediaFactoryEvent) {
        trace('AKAMAI PLUGIN LOADED!');
                                    playMediaElement();
                          private function playMediaElement() {
                                    if(mediaPlayer == null) {
                                              mediaPlayer = new MediaPlayer();
                                    if(mediaContainer == null) {
                                              mediaContainer = new MediaContainer();
                                              addChild(mediaContainer);
                                    mediaContainer.addMediaElement(mediaElement);
                                    mediaPlayer.media = mediaElement;
                                    for each(var foo:* in mediaElement.metadata) {
                                              trace(foo, mediaElement.metadata[foo]); //Nothing
      and smilLoader, truncated for brevity (xmlLoader is just a class which loads the XML and ObjEvent is just an Event which can pass Objects)
      package
                import flash.net.URLRequest;
                import org.osmf.net.DynamicStreamingItem;
                public class SmilLoader extends EventDispatcher
                          private var xmlLoader:XMLLoader = null;
                          private var _resource:DynamicStreamingResource = null;
                          public function SmilLoader()
                          public function close():void {
                                    if(xmlLoader != null) {
                                              xmlLoader.removeEventListener(ObjEvent.COMPLETE, XMLLoaded);
                                              xmlLoader.closeAll();
                                              xmlLoader = null;
                          public function load(str:String) {
                                    close();
                                    _resource = null;
                                    xmlLoader = new XMLLoader();
                                    xmlLoader.addEventListener(ObjEvent.COMPLETE, XMLLoaded);
                                    xmlLoader.loadXML(new URLRequest(str));
                          private function XMLLoaded(evt:ObjEvent) {
                                    var headNode:XML;
                                    var bodyNode:XML;
                                    var xmlNode:XML;
                                    var videoNode:XML;
                                    var videoObj:Object;
                                    var httpBase:String = null;
                                    var videos:Array = [];
                                    var item:DynamicStreamingItem;
                                    var vector:Vector.<DynamicStreamingItem> = new Vector.<DynamicStreamingItem>();
                                    for each(xmlNode in evt.target.xmlData.elements()) {
                                              switch(xmlNode.localName().toLowerCase()) {
                                                        case 'head': headNode = xmlNode; break;
                                                        case 'body': bodyNode = xmlNode; break;
        default: break;
                                    if(headNode.length()) {
                                              for each(xmlNode in headNode.elements()) {
                                                        if(xmlNode.localName().toLowerCase() == 'meta') {
        if(xmlNode.@name.toString().toLowerCase() == 'httpbase') {
        httpBase = xmlNode.@content.toString();
                                    if(httpBase != null) {
                                              for each(xmlNode in bodyNode.elements()) {
                                                        if(xmlNode.localName().toLowerCase() == 'switch') {
        for each(videoNode in xmlNode.elements()) {
        if(videoNode.localName().toLowerCase() == 'video') {
        videos.push({src: videoNode.@src.toString(), bitrate: videoNode.attribute('system-bitrate').toString()});
                                    if(videos.length > 0) {
                                              _resource = new DynamicStreamingResource(httpBase);
                                              for each(videoObj in videos) {
                                                        vector.push(new DynamicStreamingItem (videoObj.src, videoObj.bitrate));
                                              _resource.streamItems = vector;
                                              dispatchEvent(new ObjEvent(ObjEvent.COMPLETE, {resource: _resource}));
                                    } else {
        trace('ERROR IN FILE!');
                                    close();
      The trace is fine:
      SMIL LOADED!
      Just no video...
      Thanks in advance!
        • 1. Re: CloudFiles, Akamai, SMIL
          DavidKomer Level 1
          Oh interesting... it seems to work with rtmp... what do I change to make it work with http?
          • 2. Re: CloudFiles, Akamai, SMIL
            DavidKomer Level 1
            didn't realize there already existed a SMIL plugin... here's my updated code, which still doesn't work (but does work when using a rtmp-powered smil file):
            package
                      import org.osmf.events.DynamicStreamEvent;
                      import org.osmf.events.MediaPlayerStateChangeEvent;
                      import org.osmf.smil.SMILPluginInfo;
                                private var mediaFactory:MediaFactory = null;
                                private var _src:String = null;
                                private var _pluginsToLoad:Array = null;
                                          super();
              this.src = "http://tjandpals.com/xmlfiles/streams/hdnetwork/promo/video_tour.smil";
              //this.src = "http://mediapm.edgesuite.net/ovp/content/demo/smil/elephants_dream.smil";
                                          if(_src == str || str == null) {
              return;
                                          close();
                                          _src = str;
                                          mediaFactory = new DefaultMediaFactory();
                                          loadPlugins([new AkamaiBasicStreamingPluginInfo(), new SMILPluginInfo()]);
                                public function close() {
                                          stop();
                                                    mediaPlayer.removeEventListener(MediaPlayerStateChangeEvent.MEDIA_PLA YER_STATE_CHANGE, playerStateChange);
                                                    mediaPlayer.removeEventListener(DynamicStreamEvent.SWITCHING_CHANGE, dynamicStreamChange);
                                          mediaPlayer = null;
                                          mediaFactory = null;
                                          _pluginsToLoad = null;
                                          _src = null;
                                                    mediaPlayer.stop();
                                private function loadPlugins(__pluginsToLoad:Array = null) {
                                          if(__pluginsToLoad != null) {
                                                    _pluginsToLoad = __pluginsToLoad;
                                          if(_pluginsToLoad.length) {
                                                    loadPlugin(_pluginsToLoad.shift());
                                          } else {
                                                    allPluginsLoaded();
                                private function loadPlugin(source:PluginInfo):void {
                                          var pluginResource:MediaResourceBase;
                                          pluginResource = new PluginInfoResource(source);
                                          loadPluginFromResource(pluginResource);
                                private function loadPluginFromResource(pluginResource:MediaResourceBase):void {
                                          mediaFactory.addEventListener(MediaFactoryEvent.PLUGIN_LOAD, onPluginLoaded);
                                          mediaFactory.addEventListener(MediaFactoryEvent.PLUGIN_LOAD_ERROR, onPluginLoadFailed);
                                private function onPluginLoaded(event:MediaFactoryEvent):void {
              trace("Plugin loaded");
                                          loadPlugins();
                                private function onPluginLoadFailed(event:MediaFactoryEvent):void {
              trace("Could not load Plugin");
                                          loadPlugins();
                                private function allPluginsLoaded():void {
              trace('All plugins loaded!');
                                          loadMedia();
                                private function loadMedia() {
                                          var mediaResource:URLResource = new URLResource(_src);
                                          trace(mediaElement);
                                          playMediaElement();
                                                    mediaPlayer.addEventListener(MediaPlayerStateChangeEvent.MEDIA_PLAYER _STATE_CHANGE, playerStateChange);
                                                    mediaPlayer.addEventListener(DynamicStreamEvent.SWITCHING_CHANGE, dynamicStreamChange);
                                private function playerStateChange(evt:MediaPlayerStateChangeEvent) {
                                          trace(evt.state);
                                private function dynamicStreamChange(evt:DynamicStreamEvent) {
                                          var player:MediaPlayer = evt.target as MediaPlayer;
                                          trace('switched dynamic stream to:', player.currentDynamicStreamIndex);
