2 Replies Latest reply on Jul 16, 2012 6:53 AM by s22b22
    SplitViewNavigator without autoHideFirstNavigator=true issues
    Prem Radhakrishnan Level 1
      I am trying to use the SplitViewNavigator without the autoHideFirstNavigator. I want to do it programmatically so I can have user interaction to hide it and display the button for the callout or on orientation change.
      So that works great, I do
      var svn:SplitViewNavigator = FlexGlobals.topLevelApplication.mainSvn as SplitViewNavigator;
                                              svn.getViewNavigatorAt(0).visible = false;
      and I can call showFirstViewNavigatorInPopup() to display the popup
      The problem is if I want to restore it
      If I do
                                    svn.hideViewNavigatorPopUp();
                                    svn.getViewNavigatorAt(0).visible = true;
      Nothing happens , the first pane is not restored !!! Any ideas as to what I am doing wrong ? According to the documentation it says "After closing the popup, the navigator that was shown remains invisible unless autoHideFirstViewNavigator is true and the device orientation is landscape. In all other cases, the visibility of the first navigator needs to be set to true to make it visible again."
        • 1. Re: SplitViewNavigator without autoHideFirstNavigator=true issues
          I have found no resolution to this ! Anyone from Adobe please help ?
          • 2. Re: SplitViewNavigator without autoHideFirstNavigator=true issues
            s22b22
            Did you succeed ?
            There is three ways to solve your problem.
            First one : the user can act on the visibility when he wants
            Affect a min and a max widthes to the 'mobile' wiew
            this widthes can be absolute or relative
            the min width must not be 0,
            20 is a good value to allow the user to rollOver
            Add events listeners,  rollOver and rollOut
            on roll over affect max, on rollout affect min width
            a tip : when you change the width of the smallest view, (ie the mobile wiew), you'll have to force the other one to 100 %, to force refresh
            Second one : you programaticly acts
            Dont use visibility, use width
            smaller.width = 0;
            other.percentWidth = 100;
            third way : You offer the user a Slider,
            this slider is in the mobile view
            this slider is declared as is
            liveDragging="true"
            maximum="40"
            minimum="20"
            value="40"
            and on changeEvent
               var splitNavigator:SplitViewNavigator = navigator.parentNavigator as SplitViewNavigator;
               var listeVw:ViewNavigator = splitNavigator.getViewNavigatorAt(0) as ViewNavigator;
               listeVw.percentWidth = slid.value;
               var detailVw:ViewNavigator = splitNavigator.getViewNavigatorAt(1) as ViewNavigator;
               detailVw.percentWidth = 100;"
            in this example
            - listeVw is the small, mobile view
            - detailVw the bigger one
            Be sure that  autoHideFirstViewNavigator="false"
            It works fine, on both of the orientations of the device (tested only with iPad yet)
            Hoping it's helpfull
            Tell me back : if you're still unsuccessfull, i'll send you a small project
            Serge Boujo
