1 Reply Latest reply on Mar 29, 2012 9:49 AM by flexfun
    Looping through an array to get the index for each measure in a combo box
    flexfun Level 1
      Hi folks,
      I am working on a web application that has two combo boxes, one for year (called yearcombo) and for measures (called myURL) for that selected year, and also two radiobuttons (in radioBtnGroup). I have two years and a bunch of measure for each year. I  have a map tool tip that when you mouse over the county you see a measure for that specific year. However I have a bunch of measures for each year and I want to be able to loop through the measures (which are in an array collection inside a combobox) so my "if" expression can find every selectedIndex and bring me the tool tip for that selected measure for that selected radio button. Right now I would have to create if statements for each measure (each selectedIndex inside the myURL combobox)and each radiobutton (inside the radioBtnGroup) instead of creating a if expression to get a map tip tool for each measure. I know I would have to create a loop to search for these indexes and enter that in the if expression and also change the graphic.attributes to reflect the right measure or index selected. Do you API for Flex wizards  can give me any tips on how to code this according to my code below ? Any  help is greatly appreciated! (the print scree is attached)Click image for larger version  Name: screen_capture_map.jpg Views: 2 Size: 97.2 KB ID: 13106
      Below is the code snippet:
      if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 0 && radioBtnGroup.selectedValue == 0)
      fLayer.definitionExpression = "DATA_YEAR_TXT like '2007'"
      var graphic:Graphic = Graphic(event.currentTarget);
      graphic.symbol = mouseOverSymbol;
      var htmlText:String = graphic.attributes.htmlText;
      var textArea:TextArea = new TextArea();
      try{
      textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForDirIndOut.toString()
      myMap.infoWindow.content=textArea
      myMap.infoWindow.label = graphic.attributes.NAME;
      myMap.infoWindow.closeButtonVisible = false;
      myMap.infoWindow.show(myMap.toMapFromStage(event.stageX, event.stageY));}
      catch(error:Error) {
      trace("Caught Error: "+error);
      And below is the combo boxes with the arrays
      <mx:FormItem label="Year        :"  >
      <mx:ComboBox   id="yearcombo" selectedIndex="0" labelField="label" width="100%" change="changeEvt(event)"  >
      <mx:ArrayCollection id="year"  >
      <fx:Object label="2007"  year="2007" />
      <fx:Object label="2009"  year="2009" />
      </mx:ArrayCollection>
      </mx:ComboBox>
      </mx:FormItem>
      <mx:FormItem label="Measure:">
      <mx:ComboBox   id="myURL" selectedIndex="8" width="80%" mouseOver="clickEv2(event)" close="closeHandler(event)">
      <mx:ArrayCollection id="measures"   >
      <fx:Object id="forindout07" labeltext="2007 Forestry Industry Output" label="Forestry Industry Output " value="RADIO_BUTTONS/TFEI_07_forest_industry_output" year="2007"  />
      <fx:Object id="foremp07" label="2007 Forestry Employment " value="RADIO_BUTTONS/TFEI_07_forest_employment" year="2007" />
      <fx:Object id="forlabinc07" label="2007 Forestry Labor Income " value="RADIO_BUTTONS/TFEI_07_forest_labincome" year="2007" />
      <fx:Object id="forindbustax07" label="2007 Forestry Indirect Business Tax" value="RADIO_BUTTONS/TFEI_07_forest_business_tax" year="2007" />
      <fx:Object id="forindout09" label="Forestry Industry Output " value="RADIO_BUTTONS/TFEI_09_forest_industry_output" year="2009"  />
      <fx:Object id="foremp09" label="2009 Forestry Employment " value="RADIO_BUTTONS/TFEI_09_forest_employment" year="2009" />
      <fx:Object id="forlabinc09" label="2009 Forestry Labor Income " value="RADIO_BUTTONS/TFEI_09_forest_labincome" year="2009" />
      <fx:Object id="forindbustax09" label="2009 Forestry Indirect Business Tax" value="RADIO_BUTTONS/TFEI_09_forest_business_tax" year="2009" />
      <fx:Object id="blank" label=" "  />
      </mx:ArrayCollection> screen_capture_map.jpg
        • 1. Re: Looping through an array to get the index for each measure in a combo box
          flexfun Level 1
          And here is the entire code
          <mx:Application
                          xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          xmlns:esri="http://www.esri.com/2008/ags"
                          paddingBottom="8" paddingLeft="8"
                          paddingRight="8" paddingTop="8"
                          backgroundColor="0xffffff"
                          layout="vertical" >
              <!-- Start Declarations -->
          <fx:Declarations>
                  <esri:SimpleFillSymbol id="mouseOverSymbol" alpha="0.5" color="0x808080">
                      <esri:SimpleLineSymbol width="0" color="#000000"/>
                  </esri:SimpleFillSymbol>
                  <esri:SimpleFillSymbol id="defaultsym" alpha="0.01" color="#E0E0E0"   >
                      <esri:SimpleLineSymbol width="1" color="#000000"/>
              <!-- End Declarations -->
          </fx:Declarations>
              <fx:Script>
                  <![CDATA[
                      import com.esri.ags.Graphic;
                      import com.esri.ags.SpatialReference;
                      import com.esri.ags.esri_internal;
                      import com.esri.ags.events.GraphicEvent;
                      import com.esri.ags.geometry.Extent;
                      import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
                      import com.esri.ags.symbols.SimpleFillSymbol;
                      import com.esri.ags.symbols.SimpleLineSymbol;
                      import flash.utils.flash_proxy;
                      import mx.collections.ArrayCollection;
                      import mx.controls.Alert;
                      import mx.controls.RadioButton;
                      import mx.controls.TextArea;
                      import mx.events.DropdownEvent;
                      import mx.events.ItemClickEvent;
                      import mx.rpc.Fault;
                      import mx.rpc.events.FaultEvent;
                      import flash.display.Sprite;
                      import flash.events.ErrorEvent;
                      import flash.events.MouseEvent;
                      private function closeHandler(evt:DropdownEvent):void {
                          myLabel.text = ComboBox(evt.target).selectedItem.labeltext;
                      private function loadLayerName():void
                          myLegend.layers = null;
                          layerPanel.removeAllChildren();
                          //loop through each layer and add as a radiobutton
                          for(var i:uint = 0; i < (dynamicLayer.layerInfos.length); i++)
                              var radioBtn:RadioButton = new RadioButton;
                              radioBtn.groupName = "radioBtnGroup";
                              radioBtn.value = i;
                              radioBtn.label = dynamicLayer.layerInfos[i].name;
                              if (dynamicLayer.layerInfos[i].name == "Direct Impact (Million $)")
                                  radioBtn.label = "Direct Impact";
                              else if (dynamicLayer.layerInfos[i].name == "Total Impact (Million $)")
                              {radioBtn.label = "Total Impact";
                              else if (dynamicLayer.layerInfos[i].name == "Total Impact (Jobs)")
                              else if (dynamicLayer.layerInfos[i].name == "Direct Impact (Jobs)")
                              {radioBtn.label = "Direct Impact";
                              else
                              {radioBtn.visible= false;
                              layerPanel.addChild(radioBtn);
                          /*     myDividerBox.getDividerAt(0).visible = false; */
                          //set the visible layer the first radio button
                           radioBtnGroup.selectedValue = 0;
                           dynamicLayer.visibleLayers = new ArrayCollection([0]);
                          myLegend.layers = [dynamicLayer];
                          myLegend.visible = true;
                      private function radioClickHandler(event:ItemClickEvent):void
                          // update the visible layers to only show the layer selected
                          dynamicLayer.visibleLayers = new ArrayCollection([event.index]);
                      private function changeEvt(event:Event):void {
                      if (yearcombo.selectedItem.year == "2007")
                          measures.filterFunction=filter1
                          measures.refresh()
                          myURL.dataProvider=measures
                      else if (yearcombo.selectedItem.year == "2009")
                          measures.filterFunction=filter2
                          measures.refresh();
                  public function filter1(item:Object):Boolean
                      if (item.year=="2007") return true
                      else return false
                      public function filter2(item:Object):Boolean
                          if (item.year=="2009") return true
                          else return false
                      private function clickEvt(event:Event):void {
                              measures.filterFunction=filter3
                              measures.refresh()
                              measures.filterFunction=filter4
                              measures.refresh();
                      public function filter3(item:Object):Boolean
                          else return false
                      public function filter4(item:Object):Boolean
                          else return false
                      private function clickEv2(event:Event):void {
                              measures.filterFunction=filter5
                              measures.refresh()
                              measures.filterFunction=filter6
                              measures.refresh();
                          else if (yearcombo.selectedItem.year == 2007 && myURL.selectedIndex==8)
                      public function filter5(item:Object):Boolean
                          else return false
                      public function filter6(item:Object):Boolean
                          else return false
                      /* IF YOU WANT TO INCLUDE OTHER VALUES IN THE MAP TOOLTIP LIKE COUNTY NAME AND THE LABEL OF THE SELECTED ITEM
                      if (myURL.selectedIndex==0)
                      myTextArea.htmlText = "<b>County: </b>" + gr.attributes.NAME + "\n"
                      + "<b>Measure: </b>" + myURL.selectedItem.label + gr.attributes.ForDirIndOut.toString()
                      public function fLayer_graphicAddHandler(event:GraphicEvent):void
                          event.graphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOverHandler);
                          event.graphic.addEventListener(MouseEvent.MOUSE_OUT, onMouseOutHandler);
                      public function onMouseOverHandler(event:MouseEvent):void
                              try{
                          if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 0 && radioBtnGroup.selectedValue == 1)
                              try{
                                  textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForTotImpIndOut.toString()
                          if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 1 && radioBtnGroup.selectedValue == 0)
                              try{
                                  textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForDirEmp.toString()
                          if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 1 && radioBtnGroup.selectedValue == 1)
                              try{
                                  textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForTotImpEmp.toString()
                          if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 2 && radioBtnGroup.selectedValue == 0)
                              try{
                                  textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForDirLabInc.toString()
                          if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 2 && radioBtnGroup.selectedValue == 1)
                              try{
                                  textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForTotImpLabInc.toString()
                          if (yearcombo.selectedItem.year == "2007" && myURL.selectedIndex == 3 )
                              try{
                                  textArea.htmlText = myURL.selectedItem.label + graphic.attributes.ForIndirBusTax.toString()
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 0 && radioBtnGroup.selectedValue == 0)
                              fLayer.definitionExpression = "DATA_YEAR_TXT like '2009'"
                              try{
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 0 && radioBtnGroup.selectedValue == 1)
                              try{
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 1 && radioBtnGroup.selectedValue == 0)
                              try{
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 1 && radioBtnGroup.selectedValue == 1)
                              try{
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 2 && radioBtnGroup.selectedValue == 0)
                              try{
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 2 && radioBtnGroup.selectedValue == 1)
                              try{
                          if (yearcombo.selectedItem.year == "2009" && myURL.selectedIndex == 3 )
                              try{
                      public function onMouseOutHandler(event:MouseEvent):void
                          var gr:Graphic = Graphic(event.target);
                          gr.symbol = defaultsym;
                          myMap.infoWindow.hide();
              </fx:Script>
              <fx:Style>
                  @namespace esri "http://www.esri.com/2008/ags";
                  @namespace s "library://ns.adobe.com/flex/spark";
                  @namespace mx "library://ns.adobe.com/flex/mx";
                  @namespace components "com.esri.ags.components.*";
                  components|InfoWindow
                      content-background-alpha : 0.4;
                      background-color : #4A7138;
                      background-alpha : 0.7;
                      border-style : solid;
              </fx:Style>
              <mx:HBox   width="930" height="800"  id="mapHbox"  horizontalAlign="center" >
              <mx:HBox width="80">
              </mx:HBox>
              <mx:HBox id="myHBox" width="800" height="600" backgroundColor="0xffffff"  >
                  <mx:VBox  height="590" width="358"  >
                  <!--    <mx:Panel
                          width="356" height="100%"
                          color="0x000000"
                          borderAlpha="0.15"
                          <mx:Canvas height="100%" width="100%" backgroundColor="0xffffff" >
                              <esri:Map id="myMap" openHandCursorVisible="false"
                                        height="100%"
                                        logoVisible="false"
                                        doubleClickZoomEnabled="false"
                                        scrollWheelZoomEnabled="false"
                                        zoomSliderVisible="false"
                                        scaleBarVisible="false" scale="4000000" >
                                  <esri:extent>
                                      <esri:Extent xmin="-10736651.061900" ymin="4024099.909700" xmax="-10409195.669800" ymax="3440153.831100"      >
                                          <esri:SpatialReference wkid="102100"/>
                                      </esri:Extent>
                                  </esri:extent>
                                  <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer2"
        url="http://tfs-24279/ArcGIS/rest/services/RADIO_BUTTONS/counties_layer/MapServer" />
                                  <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" name=" "
        alpha="1"
        load="loadLayerName()"
                                                             url="http://tfs-24279/ArcGIS/rest/services/{myURL.selectedItem.value}/MapServer"   />
                                  <esri:FeatureLayer id="fLayer"
                                                     graphicAdd="fLayer_graphicAddHandler(event)"
                                                     mode="snapshot"
                                                     outFields="*"
                                                     symbol="{defaultsym}"
                                                     url= "http://tfs-24279/ArcGIS/rest/services/RADIO_BUTTONS/feature_layer_0709_five/FeatureServer/ 0" />
                              </esri:Map>
                          </mx:Canvas>
                  <!--    </mx:Panel>-->
                  </mx:VBox>
                  <mx:VBox  height="590" width="20"  >
                  </mx:VBox>
                  <mx:Canvas height="500" width="400" backgroundColor="0xffffff"
                             horizontalScrollPolicy="off"
                             verticalScrollPolicy="off" >
                      <mx:VBox  width="420" height="50%" paddingLeft="5" paddingTop="10" paddingRight="10" paddingBottom="10"
                               verticalGap="8">
                          <mx:Form  >
                                  </mx:ComboBox>
                              </mx:FormItem>
                                      <fx:Object id="forindout07" labeltext="Forestry Industry Output" label="Forestry Industry Output " value="RADIO_BUTTONS/TFEI_07_forest_industry_output" year="2007"  />
                                      <fx:Object id="foremp07" label="Forestry Employment " value="RADIO_BUTTONS/TFEI_07_forest_employment" year="2007" />
                                      <fx:Object id="forlabinc07" label="Forestry Labor Income " value="RADIO_BUTTONS/TFEI_07_forest_labincome" year="2007" />
                                      <fx:Object id="forindbustax07" label="Forestry Indirect Business Tax" value="RADIO_BUTTONS/TFEI_07_forest_business_tax" year="2007" />
                                      <fx:Object id="foremp09" label="Forestry Employment " value="RADIO_BUTTONS/TFEI_09_forest_employment" year="2009" />
                                      <fx:Object id="forlabinc09" label="Forestry Labor Income " value="RADIO_BUTTONS/TFEI_09_forest_labincome" year="2009" />
                                      <fx:Object id="forindbustax09" label="Forestry Indirect Business Tax" value="RADIO_BUTTONS/TFEI_09_forest_business_tax" year="2009" />
                              </mx:ComboBox>
                              </mx:FormItem>
                          </mx:Form>
                          <mx:VBox  id="layerPanel" width="50%" height="8%" verticalGap="3" paddingLeft="17">
                              <mx:RadioButtonGroup id="radioBtnGroup" itemClick="radioClickHandler(event)"  />
                          </mx:VBox>
                          <mx:VBox paddingLeft="17" height="50%" >
                          <mx:Canvas  id="legendPanel" width="100%"  >
                              <mx:Label id="myLabel" text=" " fontWeight="bold" />
                              <esri:Legend id="myLegend"
                                           layers="{[dynamicLayer]}"
                                           map="{myMap}" visible="false"
                                           respectCurrentMapScale="false"/>
                          </mx:Canvas>
                          <mx:TextArea width="275"  borderAlpha="0" height="200"  >
                              <mx:htmlText   >
                                  <![CDATA[<font size='11'><b>Note:</b> Counties in white indicate either no data is available for that measure or the data has been supressed due to confidentiality.</font>
                              </mx:htmlText>
                          </mx:TextArea>
                          </mx:VBox>
                      </mx:VBox>
                  </mx:Canvas>
              </mx:HBox>
              </mx:HBox>
          </mx:Application>
