3 Replies Latest reply on Apr 17, 2008 5:34 AM by Mush15
    odd problem with return from sql
    Level 1
      Hi all,
      I am having a problem retrieving a return result from an httpService
      Normally I would blame my code but the issue is not straight forward.
      The situation is I use the Httpservice to ask a PHP page to make a request (Still pretty straightforward)
      in the default case the PHP page calls a stored procedure which queries and send the result to php
      All works well
      The same setup allows the user to set paramaters that alert PHP to call a different SP
      Both SP's return the same data sets but the second SP performs additional processing.
      In the first case I get the return I expect in the second Nothing.
      My coworker thinks its a timeout issue but I have set properties for time out for both PHP and SQL
      Does anyone have any ideas?
