4 Replies Latest reply on Mar 30, 2012 8:15 AM by [Jongware]
    How To Insert Special Characters
    Zoffix222 Level 1
      Hey,
      I can't figure out how to insert special characters into a paragraph (the "Indent to Here" in this case).
      I tried text_frame.paragraphs[0].contents +=  SpecialCharacters.INDENT_HERE_TAB;  but all I get is "1397319796" instead of the actual character.
      How to insert special characters instead of those numbers?
        • 1. Re: How To Insert Special Characters
          Zoffix222 Level 1
          People viewing but no one know this one?
          Only with Adobe's creation could you have a full language manual and a forum, and still have no clue how to do the simplests of things...
          • 2. Re: How To Insert Special Characters
            What, you mean that in the 5 minutes since you posted it no-one answered? Shocking indeed.
            As you aleady found out by yourself, "contents" is the wrong type of object to stuff "SpecialCharacters" in. "contents" is the contents of text, translated into a plain Javascript string. Only when you change a single 'character', you can use "SpecialCharacters", because at that point Extendscript will see you don't want to change the "entire" string?
            • 3. Re: How To Insert Special Characters
              Zoffix222 Level 1
              No, that 50 people who were curious enough to read the message didn't know the answer. And that language reference doesn't provide a single shred of info on how to use those special characters. That's what's shocking.
              Thanks. What I found is that if I use assignment, instead of +=, then the special character is added without replacing the string.
              • 4. Re: How To Insert Special Characters
                Ah, yes, that was the term I was looking for. With your "contents += ..", the entire contents are 'read', converted into a Javascript string, and at that point you cannot insert the SpecialCharacters anymore. With a straight assignment, one at a time, it works.
                The biggest downside of this method is that you can only add one special character at a time. I guess that's just the price you have to pay for this method, working around Unicode. You'll also have the same problem if you try to read a contents string back that contains any special character ...
