10 Replies Latest reply on Jul 6, 2012 6:53 AM by Carlos1327
    Apache not working  with FMS 4.5 on Windows 2008
    Carlos1327 Newcomer
      FMS 4.5.1 Windows 2008 SP2 (64bit).
      I've searched everywhere for a possible solution to this, so my apologies if this has been asked before and my thanks for any potential help that anyone can offer to help resolve this.
      We are deploying Adobe Flash Media Server 4.5.1 on a new server but Apache does not work (does not serve html files or stream Quicktime H.264 files).
            Assorted Problems & Error messages:
      1.  The webroot/index.html page loads locally, but the HLS/HDS streams result in a 2032 error.
      2. The webroot/index.html page does not load from  external locations:
           http://63.116.232.5/index.html (does not load externally).
           http://63.116.232.6/index.html (our old server, FMS 4.0 and Windows 2003). Everything on this server works, the 2 major differences being that it is running FMS 4.x on Windows 2003.
      Some RTMP streaming works externally and internally (f4v files):
      http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232.5/vod/mp4:sample1_1 50kbps.f4v
      FMS does not stream Quicktime H.264 files even though f4v files work.
         New server (does not work): http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232.5/vod/mp4:Basketbal l.mov
                                    (f4v works): http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232.5/vod/mp4:sample1_1 50kbps.f4v
      Old server (Quicktime/H.264 file works): http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232.6/vod/mp4:Basketbal l.mov
      Apache does not serve Quicktime/H.264 files: I made sure that Apache had all of the correct mime types specified.
          Error messages and attempted solutions:
      1. Apache's erro_log file:
             a. httpd.exe: Could not determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
      2. FMS master.log file
            a. FMSHttpd -k start returned 1:
      Solutions: http://wiki.apache.org/httpd/CouldNotDetermineServerName
      1a:  Edited httpd.conf file to include ServerName 63.116.232.5
      1b: The presence of this error message also indicates that Apache httpd was unable to obtain a fully-qualified hostname by doing a reverse lookup on your server's IP address.
      In order for the server to accept external connections a reverse DNS lookup needs to be created. I created a reverse DNS lookup and  edited the /etc/hosts file to include the IPaddress, Fully Qualified Domain Name (FQDN), shortname.
      This is the format suggested by the article:
      127.0.0.1       localhost.localdomain   localhost       foo.example.com
      Running the nbtstat -a 63.116.232.5 command on the machine results in the following:
      WIN-8AIHI2J0524<00>  UNIQUE      Registered
      THS-LIBRARY-VOD<00>  GROUP       Registered
      THS-LIBRARY-VOD<1C>  GROUP       Registered
      WIN-8AIHI2J0524<20>  UNIQUE      Registered
      THS-LIBRARY-VOD<1B>  UNIQUE      Registered
      So the FQDN = WIN-8AIHI2J0524.Ths-library-vod.local
      I edited the /etc/hosts to the following (with versions using the local host ip 127.0.0.1 and the external ip address, IPv4 is being used):
      63.116.232.5 WIN-8AIHI2J0524.Ths-library-vod.local
      # The following lines are desirable for IPv6 capable hosts
      ::1 localhost ip6-localhost ip6-loopback
      fe00::0 ip6-localnet
      ff00::0 ip6-mcastprefix
      ff02::1 ip6-allnodes
      ff02::2 ip6-allrouters
      ff02::3 ip6-allhosts
      I've also read Adobe's port configuration articles and  changed the ports that Apache and FMS use as specified in the conf/fms.ini file, but nothing has worked so far. I restored everything to the original settings until I can find out exactly how to fix this.
      Thank you.
