4 Replies Latest reply on Mar 30, 2012 10:25 AM by JMBinCO
    PE10 .mpg Field & Aspect Ratio issues
    JMBinCO
      I created a AVCHD video including 100s of .mpg files (lower-field 1st). It was painfully slow to have to set Reverse Field Dominance on each. First question - why can't PE extract the field order from the file header info? why all the mickey-mouse options to determine the correct field order? In fact, I have to create separate videos of both types just to determine which looks correct. Finally I decided to convert my entire library of .mpg files to lower field 1st since that is what PE defaults to as output from DV capture. At a minimum, hence 2nd question, it would be nice if PE allowed you to select multiple clips and change RFD (reverse field dominance) all at once.
      Regarding aspect ratio, PE assumes D1/DV of 0.9091. This seems to be based on 704x480 instead of more std 720x480. So for example a 704x480 at 0.9091 would be displayed as 4:3 aspect 640x480. However, the more std 720x480 then converts to 654.55 x 480. The reason this is important is when you want to mix videos with std 4:3 images. All my .mpg/avi files seem to be just 15-16 pixels wider than the std 640x480. So I have to correct for this by cropping or spacing things apart. PE should add the option for correct aspect correction of 0.8888 instead of 0.9091.
        • 1. Re: PE10 .mpg Field & Aspect Ratio issues
          If you properly set up your project for AVCHD or even MPEG footage, you don't need to mess around with any of these things, JMB. They're handled automatically by the project preset. (I can't imagine any workflow that would involve manually changing the field dominance one clip at a time!)
          When you started your Premiere Elements project, which project settings did you select?
          • 2. Re: PE10 .mpg Field & Aspect Ratio issues
            JMBinCO Level 1
            I have project setup for AVCHD (1920x1080) and plan to output bluray. So this assumes high-field 1st. Thus I did not need to alter any imported videos from my .mod or .mts files since they were high field first. However, all my .mpg files (lower field 1st) needed individual modification to set the reverse field dominance. No automatic stuff.
            I know my .mpg files work correct as is in other players (WM & VLC) as well as play nicely in PE organizer and PE when doing DV preset.
            You would hope that when you choose an AVCHD preset (hi-field 1st) and it should know the .mpg files are low-field 1st, then it would automatically reverse field order them, but nope.
            • 3. Re: PE10 .mpg Field & Aspect Ratio issues
              You're mixing AVCHD and standard def video in an AVCHD project? That's not a wise workflow.
              I also don't know any reason you would have to alter your field dominance if you are using AVCHD in a project set up for AVC HD.
              Is this standard AVCHD from a camcorder? What model of camcorder is this video coming from and which settings was it shot with?
              Something just doesn't make sense here.
              • 4. Re: PE10 .mpg Field & Aspect Ratio issues
                JMBinCO Level 1
                I indicated above that I have no trouble with AVCHD inputs (.mts).
                What's wrong with mixing .mpg stddef videos with AVCHD? I created a project that shows multi-year footage. Some of it is HD and some of it is old stddef 8mm/DV (.mpg). Actually, mixing stddef on HD output is great, because you have so much resolution to work with. I can actually watch 4 stddef videos on the same screen w/o losing track. Such intense display of material is quite entertaining and you can't take your eyes off trying to catch everything.
                On a side note, I created this 2 hr blu-ray project (AVCHD output of ~20GB) using hundreds of images, stddef & hddef videos, and up to 12 stacked video channels. The encoding process only took 2 hrs and used a max of 20GB of ram (32GB installed). Very happy with 64-b PE10!
